Vq25det info
Old 04-30-2014, 10:43 AM
Sickjdm4's Avatar
Vq25det info
I wanted to turbo my G35. 6 speed .
I saw on ebay VQ25det turbo motor I would like to get more info on this motor .
Vq35 is weak on less u build up the bottom end .
So the last swap I would try in my G would have to be the 2jzgte with I know have been done .
Old 04-30-2014, 12:17 PM
Urbanengineer's Avatar
Received 1,018 Likes on 936 Posts
Talk to Andy from this forum. He pulled a turbo off one of those to build his vq35.
Old 04-30-2014, 01:30 PM
Sickjdm4's Avatar
Which Andy there's more than one .
Old 04-30-2014, 01:36 PM
It was a VQ 30 my bad;
Shared post from 'G35Driver' by andy_cliff from thread 'Andy_Cliff's Nissan Skyline 350GT progress thread':
Hey all, im Andy. Im from New Zealand, you know the place? No? 2 or so hours away from Australia. I own a 03 Nissan Skyline 350GT. (JDM G35)
I purchased the car late 2013 with 120,000km's(74500 miles) after selling one of my old cars.
When i got the car, it looked just like this one. Stock as stock goes. The only thing it had was tinted windows.
Since then i have done the following.
- Painted the headlight inners black and sanded/UV protected the front lights.
- Changed the 10000k HIDs it had to 6000k.
- Removed the Skyline & 350GT badges
- Painted the "rear diffuser" plastic
- Painted the grill black to suit the lights
- Put some 19x9.5 Vossen CV3 reps on (temp wheels)
- Remove stock resonator and replaced with a CAI
- Added a HKS Super panel filter
- Made a good quality grounding kit and fitted
What i have ordered for the near future:
- Gloss black roof wrap
- Tanabe 350z springs
- Stock 350z shocks
What i will be ordering shortly:
- Motordyne 5/16 Plenum spacer
- Fujitsubo Catback exhaust
- Gialla style bootlip spoiler or the stock surfboard spoiler
- Wider wheels
These are the wheels i bought:
Late night test fit:
Fitted:
Desired setup with the current wheels:
Ground kit made/fitted. CAI & Filter fitted also:
In the long run i am also going to be doing a +T conversion using the VQ30DET manifolds.
I am going to be using VQ30det manifolds for the build. (Thankful for NZ having access to RHD VQ30DET vehicles).
The manifolds will not be modified. The turbo position is going to remain in the lower position like the VQ25DET & VQ30DET. This will be achievable with the use of a HKS 3037 like the HKS Single Turbo kit. Surprisingly enough, HKS simply used the VQ25/30DET manifolds for their kits Nice!
I found out a fair amount of info on the HKS Single Turbo setup so i plan to base my kit around theirs.
HKS Single Turbo Kit - 350z/G35 approx 270rwkw-300rwkw (360rwhp-400rwhp approx.)
The last thing i want to do is have to do this twice so im going to be spending a little more more money on the turbo and waste gate setup.
Calculating the build costs it looks a little like this. Take into account this is with QUALITY core parts and is an estimate from current prices here in NZ:
VQ30det manifold - $50
HKS 3037 Turbo - $700
Turbosmart OR HKS 60mm wastegate - $500
Intercooler & Piping - $400
Hoses/Fittings - $100
Deatschwerks Injectors - $300
Deatschwerks fuel pump - $155
Oil pan spacer - $180
Oil feed lines/Return lines - $125
Catch can setup - $80
Sparkplugs - $80
AM Radiator - $200
Genuine HKS BOV - $80
Approx. total before tune = $2,950 NZD ($2449 USD)
That is less than what i have seen the Turbonetics kits going for
Not quite pennies but very reasonable for a supposedly reliable and well put together kit.
There are a couple of the things which you could strip back if you were wanting to be on a very tight budget such as the radiator and oil pan spacer etc.
Updates to come.
Cheers
Shared via Forum Runner.
Old 04-30-2014, 02:34 PM
Jeff92se's Avatar
Red Card Crew
You have a pic of the VQ30det? I thought they were all transverse mounted for FWD applications? I haven't researched these for some time
Old 04-30-2014, 04:08 PM
Sickjdm4's Avatar
What's up Andy I'm just trying to see if the vq25det would be a good swap for my V35 (g35)
Cause that motor comes turbo (vq25gte)
What's the pros and cons
Is the swap worth doing ?
In the USA no one has done this swap . That I know about .
I know the vq35 motor. That comes in the V35 (G35 ) isn't good to turbo hence the sleeves .
Old 04-30-2014, 05:29 PM
GR6RR's Avatar
LOL. ^ was supposed to be a private message possibly?
Urbanengineer (04-30-2014)
Old 04-30-2014, 07:50 PM
Sickjdm4's Avatar
not really this topic can help others
Old 05-04-2014, 03:01 PM
Sickjdm4's Avatar
Guys I need more info.
Old 03-14-2017, 02:54 PM
Timothy Farmer's Avatar
has anyone still not attempted this swap yet because i plan on doing it either way but have a few questions as far as using the 25det ecu and autotransmission goes .
Old 03-17-2017, 04:15 AM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
Not that I have ever seen on here......
The Fixer
Steering & Suspension
11-01-2015 03:26 PM
Rose M
10-12-2015 10:00 AM
TurTLe*
09-29-2015 01:43 PM
ncg35guy
09-24-2015 04:53 PM
wayneside
SouthEast
09-23-2015 06:38 AM
Quick Reply: Vq25det info
