Exterior-Vendor Includes spoilers, body kits, tail lights, gauges, shift knobs, and other styling components
Aluminum Under Tray (Splash Shield) for G35/350Z/G35X/G37/G37X
Old 04-21-2012, 03:31 PM
Tolboothwilley™'s Avatar
If you are like me, someday you will be cruising on the highway and suddenly hear a rubbing/scratching sound coming from under your engine. The stock plastic splash shield pulls away from the bumper and leaves you wanting something better, well here it is:
* Aluminum - to keep it lightweight
* Better Protection for your engine
* OEM ground clearance or better
* Extra rigidity at high speeds
* OIL DOOR - if you change your own oil this will make it much quicker. 2 Bolts and you have access to filter and drain plug
Raw Aluminum and Black Powder Coated options are available for all parts
ENGINE UNDER TRAYS
G35 / 350Z
2003-2006 RWD G35 Sedan
2003-2007 G35 Coupe
2003-2009 350Z
Go here to purchase >>>>> G35 & 350Z Aluminum Engine Under Tray
2004-2006 G35X
Go here to purchase >>>>> AWD G35X Aluminum Engine Under Tray
HR G35, G37 & 370Z
2007-2008 RWD G35 Sedan
2008-2012 G37 Coupe
2009-2012 G37 Sedan RWD only
2009-2012 370Z
Go here to purchase >>>>> Infiniti G35HR and G37 Under Tray
HR G35X & G37X
2007-2008 AWD G35X Sedan
2009-2013 G37X Coupe
2009-2013 G37X Sedan AWD only
Go here to purchase >>>>> Infiniti G37X & 2007-2008 G35X Under Tray
REAR/BELL HOUSING UNDERTRAYS
Go here to purchase >>>>> RWD G35 Sedan Bell House Tray
Installed Brushed Combo on a sedan(pic courtesy of riforever80)
2003-2007 G35 Coupe
Go here to purchase >>>>> G35 Coupe Bell House Under Tray
2004-2006 G35X
Go here to purchase >>>>> 2004-2006 G35X Bell House Panel
The following 3 users liked this post by Tolboothwilley™:
GEOG35 (04-24-2012), indy_500 (10-25-2012), manvelmk (02-12-2013)
Old 04-21-2012, 03:48 PM
eodg35's Avatar
do the holes match up to drain the coolant?
Old 04-21-2012, 06:29 PM
Tollboothwilley's Avatar
Yes. All holes match to stock. There are two drainage holes..one for coolant and one for auto trans cooler lines.
Old 04-21-2012, 06:31 PM
thescreensavers's Avatar
Mr.202?
Very nice! Great price too, Mine is falling apart, will be talking to you in the future.
Old 04-21-2012, 11:04 PM
SuperCleanG's Avatar
How long is shipping to 55306? Will be ordering this is the next 2 weeks.. tired of trying to get the oem guard to work with aftermarket bumpers.
Old 04-21-2012, 11:12 PM
parhamm1's Avatar
Wish these things were made slammed car friendly...
Old 04-21-2012, 11:22 PM
redpearl99's Avatar
congrats on being back tolbooth!
Blue Dream (04-27-2012)
Old 04-21-2012, 11:23 PM
I'll be here - just let me know.
Shipping to MN will take 3-4 days - i ship via UPS. What problems have you been experiencing with aftermarket bumpers? I have made some special front pieces for a few people where the new bumper is longer than stock.
I know several people running this who are "slammed", some on bags. How low are you? This generally helps with clearance. Depending on your situation some custom adjustments can be made.
Old 04-21-2012, 11:34 PM
Thanks buddy. Just like coming back home! LOL.
Old 04-22-2012, 12:00 AM
NFSP G35's Avatar
? = 2B || !2B
I can personally vouch for these.
I've had one of Toolbooth's trays on my car for nearly 2 years now. It's worth it for the oil change door alone
But seriously though, sooooo much better than the plastic piece of crap (that came loose and scared the crap out of me after a high speed run BTW)
Tolboothwilley™ (04-22-2012)
Old 04-22-2012, 01:29 AM
3truman's Avatar
+1 to all positive comments! I have had mine for a while saved me a couple times, pine cones, rocks, aluminum cans, whatever blows into the road while your driving..........
Plus it strengthens your front bumper, I have a strafe nismo rep(fiberglass) and I hit a retread from a semi truck on the freeway. Only scratched the paint, no bumper damage.
Oil changes take only a few minutes too!
Old 04-22-2012, 08:36 AM
This time around I have the Kuruma poly bumper and it sits up against the plastic undertray, which is good since it keeps it from falling, however it needs to be drilled to attach bolts to the 2 pieces. Does the new piece just sit flush, is there a gap or does it have to be attached?
I will also be pretty low, I was under the impression this helps as stated by others in this thread
Old 04-22-2012, 10:23 AM
ccc123pm's Avatar
X
Good to see you back from your extended hiatus. PM me when you make another run of the v35 AWD.
Old 04-22-2012, 10:53 AM
Phil DeVtec's Avatar
I'll take one. How do I order?
Old 04-22-2012, 12:25 PM
The shroud is 3 pieces. The front piece which connects to the bumper will extend to about where the stock on is. You will want to get some extra clips (+$5) since your new bumper doesn't have them. It will let you mount the shroud up very easily.
I have a few G35X (for 2003-2006) in stock right now. They are powdercoated black. I'll send you a PM.
Sending you a PM.
Quick Reply: Aluminum Under Tray (Splash Shield) for G35/350Z/G35X/G37/G37X
