G35 & G37, Coupes & Sedans
How many miles can you drive after gas light comes on?
Old 06-11-2006, 04:06 PM
g35916's Avatar
hey there, i was just wondering if any of you knew how many miles we are able to drive when the gas indicator light comes on?
Old 06-11-2006, 04:20 PM
ISMSOLUTIONS's Avatar
I've gone about 70 miles - filled up and the car took 18.7 gallons. I think there's about 2-3 gallons of reserve.
Rick
Old 06-11-2006, 04:38 PM
TheTrance's Avatar
i think about 5 kilometers..whatever that is in miles
Old 06-11-2006, 04:55 PM
jd2k1's Avatar
I've gone 60 miles with the light on if I don't drive too crazy. Usually there's about 3-4 gallons left when my light comes on.
Old 06-11-2006, 05:06 PM
Msedanman's Avatar
O.F. Administrator
I've gone about 100 miles, but the tank is tapped by then. I wouldn't recommend it.
C.
Old 06-11-2006, 07:33 PM
OCG35's Avatar
I don’t go more than 20-25 after lights comes on... Something I've noticed though - generally I fill up at about 320 miles that's just about before the light normally comes on... with that I avg 17-18mpg (AT)... however if I fill up when there is about 1/4 tank left my avg mpg works out to 18-19 consistently... what's up with that
Old 06-11-2006, 07:49 PM
MixturePinoy's Avatar
Once the light goes on, i fill up... I'm too scared to be one of those guys on the side of the road waiting for someone to get em gas
Old 06-11-2006, 07:52 PM
kevink's Avatar
Other than the worry about running out, I wouldn't want to damage my fuel pump by running too low.
Some cars, like my previous Ford, has the pump in the tank and depend on the surrounding gas for cooling. One time, I let it get too low, and on the trip home the fuel pump went out.
Old 06-12-2006, 04:58 PM
litkaj's Avatar
The fuel light comes on in my car at 4 gal, dead on. Once it comes on I usually make two trips back and forth to work before I fill up.
Old 06-12-2006, 05:56 PM
Mr. Wonderful's Avatar
Mine took 17 gallons after the light came on.
Old 06-12-2006, 10:39 PM
elau's Avatar
This is great info. My first encounter with the gas light was this weekend. I wasn't sure how much further I could go, so I stopped at the first station I saw. However, I noticed the light came on while the needle was sitting on the first notch. That led me to believe I probably had at least 20 miles before I would be in some serious trouble. Thanks guys!!
Old 06-13-2006, 09:51 AM
da mayor's Avatar
usually go 50 miles easy w/ the light on
Old 06-13-2006, 10:29 AM
madchef's Avatar
I completly ignore the light now, because it comes on way too soon. I'd say I get at least 100 miles after the light comes on.
Old 06-15-2006, 01:45 PM
agspin's Avatar
My gas gauge sucks. The light comes on at about 250 miles. I drive it to 360 (over 100 miles) and it still only takes about 17.5 gallons which means there is still 2.5 gallons in the tank
Old 06-21-2006, 12:50 AM
DG G35's Avatar
Typically about 4 gallons are left when the light comes on.
Quick Reply: How many miles can you drive after gas light comes on?
