Hot start, rough running
Hi all,
I'm having an intermittent issue with my G35. 04, coupe, 6MT, 86k KMs. Tanabe Medallion Touring exhaust and Y-Pipe, everything else OEM.
Immediately after a hot start (that is, if the car has any heat registering on the gauge, not necessarily operating temp), the car shudders and shakes, even if i bring the RPM's up, It just shakes at a higher frequency following rpm. After about 10-20 seconds, it goes away after i give it some more gas (not driving, just at a stop). The car will try to idle, but will shake and shudder while doing it. It first happened a couple months ago, but now has been happening more and more frequently. I tried today to restart the car right after it shut off (within 10 seconds) and it fired back up no problem. So i'm rather confused right now. No codes.
What im thinking:
Original spark plugs?
MAF?
Dirty TB?
Vacuum leak?
Never seen anyone with this issue and I know the whole history of this car as my father purchased it new.
Any ideas?
What im thinking:
MAF?
Dirty TB?
Vacuum leak?
Any ideas?
on
G35 Rev-Up 6MT
TPS
IAC Valve
EGR Valve
Vacuum Lines
Quick and easy way to test, let the car run, and spray some Carb Cleaner on the vacuum lines (close up and slow bursts all along the lines) to see if it makes your engine revup. If that occurs, it's a vacuum leak. If not, it's one of those three sensors/valves.
(Might be a coil pack going bad, but unlikely, because its intermittent :/)
gq916
Engine - Intake/Fuel
08-08-2016 05:41 PM
