Show Your Support Become A Premier Member
Activity Stream: Show All | New Threads | New Posts | New Pictures | Popular Threads | Lonely Threads | Only Vendor Threads | New Picture Comments | New Profile Comments |
Go Back   G35Driver > General Discussion > G35 Sedan V35 2003-06
Sign in using an external account
Register Forgot Password?
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
submit to reddit
Thread Tools Search this Thread Rate Thread Display Modes
Old 03-08-2010, 04:32 PM
ActionAl's Avatar
Garage is empty, add now
Broken Drivers Seat Frame
I have a 2004 sedan with a rocking chair for a drivers seat now. I took it into the dealer for an estimate to fix it and was told the frame is broken and it would cost a little over $1200 to fix it. OOCH!
I'm not a big guy, about 200lbs, so I'm not sure how I broke the frame. I do know that when I had my car repaired from being rear-ended a few years back, I complained about the drivers seat being up higher and it wouldn't lower to where I remember. The body shop sent it to a local Infintii dealer, it felt better but again not as good as I remember.
Is it possible that something in the frame was bent and the dealer just bent it back? So, now after a few years the frame broke from me jumping in and out?
Anybody else has a broke drivers seat frame and have it repaired?
I think $1200 for a new seat frame crazy. Any ideas on how to get this repaired for less?
__________________
2004 G35x -> 2010 G37xS: Anniversary Edition
Old 03-08-2010, 04:45 PM
socialconflicts's Avatar
Points: 6,935, Level: 54
Points: 6,935, Level: 54 Points: 6,935, Level: 54 Points: 6,935, Level: 54
Level up: 93%, 15 Points needed
Level up: 93% Level up: 93% Level up: 93%
Activity: 15.1%
Activity: 15.1% Activity: 15.1% Activity: 15.1%
just consider a complete new seat for that price! lol
seriously i would just go to an auto place and find a messed up G and replace the needed part. im sure they wont overcharge you there.
Old 03-08-2010, 04:46 PM
Points: 4,870, Level: 44
Points: 4,870, Level: 44 Points: 4,870, Level: 44 Points: 4,870, Level: 44
Level up: 60%, 80 Points needed
Level up: 60% Level up: 60% Level up: 60%
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
I'm not surprised by the quote. Could you take a picture? It would help us help you. If its something that's welded on to the body of the car it might be an issue. However, if it's something as simple as a broken bolt, or a derailing, that's not so bad.
__________________
2003.0 G35 Sedan 5AT
Old 03-08-2010, 05:15 PM
Mustang5L5's Avatar
Points: 10,623, Level: 68
Points: 10,623, Level: 68 Points: 10,623, Level: 68 Points: 10,623, Level: 68
Level up: 44%, 227 Points needed
Level up: 44% Level up: 44% Level up: 44%
Activity: 0%
I had my driver's seat frame replaced under warranty. I felt it rocking, so i took it in and they replaced it. No idea how much it cost...but $1200...wow.
I'm 200 lb too and mine went around 35K miles
__________________
2006 G35x Sedan // Black Obsidian/Stone // Premium C + NAV // Stock + 35% Tint/OEM Ipod integration kit //
Old 03-08-2010, 05:19 PM
Activity: 0%
That's not a bad idea. So when you say frame, does that mean the the railing and connecting parts between the car and the seat are intact and it's just the seat itself that's just messed up? If that's the case then your better off just purchasing a seat and bolting it on yourself.
__________________
Old 03-08-2010, 05:28 PM
Points: 7,990, Level: 60
Points: 7,990, Level: 60 Points: 7,990, Level: 60 Points: 7,990, Level: 60
Level up: 20%, 160 Points needed
Level up: 20% Level up: 20% Level up: 20%
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
2004 Infiniti G35
i've had my seat track replaced/repaired 3 times!! (under warranty) and it's about to go out AGAIN. i'm only about 160 pounds.
__________________
"One side of me says, I'd like to talk to her, date her. The other side of me says, I wonder what her head would look like on a stick?"
--Edmund Kemper
Old 03-08-2010, 08:57 PM
ActionAl's Avatar
Quote:
Yeah...its just the seat rocking. The rails don't move at all. I guess I'll have to see how to seperate the seat from the frame so I can get a better look myself. I've got 132K so no warranty factory or extended.
__________________
Old 04-11-2010, 02:11 AM
ActionAl's Avatar
Problem identified
I finally made some time to pull my rocking drivers seat out and figured out the cause...a bolt had fallen out for a bracing arm. This caused excessive stress on a relatively thin part of the frame, which cracked from the stress.
I'm including pictures including the bolt that fell out laying next to the bracket it was suppose to be holding.
Lower right side of drivers seat showing the full side including the bolt laying near the spot it belongs.
Lower front bracket and frame of drivers seat with shot of bracket with bolt that was missing and showing the torn frame brace.
Close-up of bolt and the bracket where it belonged
Close-up of torn frame brace from underside angle
Close-up of torn frame brace from side angle
Close-up of torn frame brace - looking from the front
Next I'll post my repair separately when it's completed (including pictures).
__________________
Old 04-11-2010, 02:25 AM
Activity: 15.1%
damn that thing tore up, im sure u can find the part at a junk yard unless u decide to weld it back in.
GL
Old 04-11-2010, 06:37 AM
Blue Dream's Avatar
I drove ttrank's car solo
Points: 14,617, Level: 78
Points: 14,617, Level: 78 Points: 14,617, Level: 78 Points: 14,617, Level: 78
Level up: 42%, 233 Points needed
Level up: 42% Level up: 42% Level up: 42%
Activity: 56.4%
Activity: 56.4% Activity: 56.4% Activity: 56.4%
2005 Infiniti G35
Anxious to see the pics of the repair. Props to you for taking time to troubleshoot the issue and figure out the fix.
__________________
My wish in life is for world peace and people doing the right thing
Old 04-11-2010, 10:30 AM
SILVERAZG35's Avatar
Points: 8,520, Level: 62
Points: 8,520, Level: 62 Points: 8,520, Level: 62 Points: 8,520, Level: 62
Level up: 24%, 230 Points needed
Level up: 24% Level up: 24% Level up: 24%
Activity: 0.8%
How hard was it to take the seat out?
__________________
03.5 BSClear CornersNismo Kit18" Coupe WheelsTEIN Springs
Old 04-11-2010, 11:43 AM
ActionAl's Avatar
Quote:
Easier than I thought. 4 bolts hiding under plastic snap on covers. Getting the 3 cables disconnected was more trouble some. Taking off the front plastic cover, held by 2 phillips screws and few hidden snaps which attach it to the side plastic cover, gave me better access to cutting the wire ties. The connector locks are a little tricky, a small tip screw driver helps.
__________________
Old 04-11-2010, 11:53 AM
Points: 7,672, Level: 58
Points: 7,672, Level: 58 Points: 7,672, Level: 58 Points: 7,672, Level: 58
Level up: 61%, 78 Points needed
Level up: 61% Level up: 61% Level up: 61%
Activity: 26.2%
Activity: 26.2% Activity: 26.2% Activity: 26.2%
2004 Infiniti G35
Is this the same problem all creaking, loose seats have?
__________________
Old 04-11-2010, 12:14 PM
ActionAl's Avatar
Quote:
It could be...If your seat is making noise or moving, I'd pull it and see if the bolts are loose on the supports before the frame gets over stressed.
__________________
Old 04-11-2010, 12:29 PM
Points: 3,218, Level: 35
Points: 3,218, Level: 35 Points: 3,218, Level: 35 Points: 3,218, Level: 35
Level up: 12%, 132 Points needed
Level up: 12% Level up: 12% Level up: 12%
Activity: 0%
2004 Infiniti G35
I had the same exact thing happen to my 04 drivers seat. I took the seat out and welded the bracket and have never had a problem since.
__________________
04 6MT Sedan l Stillen l Magnaflow l Kinetix l Greddy l Hotchkiss l K2
submit to reddit
Tags
2003, 2004, broke, broken, coupe, driver, drivers, frame, g35, infiniti, install, rock, seat, seats, stuck
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
G35Driver.com | My350Z.com | MyG37.com | ZDriver.com |
Everyone's Contact Details
