Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
  #10381
Old 01-30-2016, 07:19 PM
Urbanengineer's Avatar
Received 1,018 Likes on 936 Posts
No sorry. Totally different generation.
  #10382
Old 01-31-2016, 10:23 AM
markc's Avatar
Originally Posted by MrTBahgs
Yea that's the same method I have been using and works perfectly.
My problem now is that I do get into diagnostic mode, but it never shows an error code, just a slow 3sec on 2 sec off blink. I believe that means there is an old code still in its memory, but it doesn't ever redisplay the old code or something. I guess I will need to have the Consult II device or whatever read it at a dealer.
I was able to reset my light and it stayed off for like a week or more, but eventually came back and I have since reset it again, every time trying to see what the actual error code is, but not getting anywhere.
If you are getting a blink code for yours, post what the sequence is and I can reference the pdf i found (forget the source) and let you know what it says. You will need something like 1 long and 6 short blinks as an example of what to expect.
I get the same 3 secs. on and 2 secs. off, repeat. I might take it to my mechanic come spring to see what he thinks.
  #10383
Old 01-31-2016, 10:25 AM
NFSP G35's Avatar
? = 2B || !2B
Correct
  #10384
Old 02-09-2016, 02:16 PM
kinman1's Avatar
2007 G35 Dome/Map light stays on all time and drain my battery. It stays on with door closed and switch in OFF position. Other door lights shut off after 15 sec. Is it the bad switch ??? I pull the fuse (room lamp) for now. Any recommendation? Dealer??
  #10385
Old 02-10-2016, 01:36 PM
thegreatkwijibo's Avatar
anyone know how to fix this:
  #10386
Old 02-10-2016, 01:41 PM
saywat?'s Avatar
if you have the broken pieces jus glue it back with strong glue
  #10387
Old 02-10-2016, 01:43 PM
Broken pieces have disappeared into oblivion.
  #10388
Old 02-10-2016, 01:46 PM
saywat?'s Avatar
then zip tie would be the next best thing aside from replacing the panel
  #10389
Old 02-10-2016, 01:55 PM
zip tie what exactly?
  #10390
Old 02-10-2016, 01:56 PM
saywat?'s Avatar
id zip tie the black plastic grommet looking thing to the panel
  #10391
Old 02-10-2016, 02:01 PM
well thats the hood release so its supposed to move. the part at the top is the busted up lever that was supposed to grab the rubber part so i could open the hood
  #10392
Old 02-10-2016, 02:03 PM
saywat?'s Avatar
yea only the cable needs to move not the black grommet part. that part is locked in place by the peice that broke. thats why i said zip tie the black part only that should hold it in place so when u tug on it only the cable moves.
  #10393
Old 02-10-2016, 02:07 PM
hmm worth a shot.
  #10394
Old 02-10-2016, 02:11 PM
saywat?'s Avatar
and stop jerking off so damn much
  #10395
Old 02-10-2016, 02:52 PM
Lartytiejdke3's Avatar
hes right you know
you only have yourself to blame for this one lol
"My masturbation helmet doesn't have naked chicks in it!
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: Random Little Question Thread
