Adding Supercharger to 2008 G35X Type S - Automatic
Hello Peeps, I am new to the forums. I have a question, if i wanted to add a supercharger to my 2008 Infiniti G35x Type S would i need to replace any other parts on my motor (Stock 3.5)? Is there a supercharger i can purchase that will work just fine with the stock motor? Only thing i have done to it at this time is adding Injen Intakes. Let me know please.
Geomar Morales (08-15-2014)
http://www.stillen.com/product/super...35-118084.html
+ installation
I guess there should be a "safe tune" for stock engine internal.
+ installation
500? maybe, if you don't beat on it. But from what I have read here, a stock block should never go over 400 for reliability. That's just opinion and there are many here that say that's not true, but if you are doing this to a daily driver, don't go wild.
Ehh, I doubt it has nearly as much to do with HP than it does with the torque you're putting down. If you're putting down 350 ft.lbs of torque, but holding it clear up into higher rpms, then you can be making and getting away with big HP numbers just fine, but if you were to try and put down 500ft.lbs at 4K rpms, regardless of HP numbers, you'd eat your chassis alive. Of course all this means squat if you don't have a decent tune; heck, you can toast your car at just 300 whp with a crappy tune.
.02
.02
