where to tap into dome lights
so i am trying to tap into the dome lights, not the switch but when doors are unlocked, door opened yada yada. trying to tap into the bcm and looked through other threads and also the fsm but have not had any luck
http://www.nicoclub.com/FSM/G35/Coup...5_Coupe/lt.pdf
pg 151 has the wiring layout but for 48, it is the opposite of what I need, it is 0 v when dome light is on and battery voltage after the map lights turn off. anyone have any info? looked through other threads but no one had a specific pin to tap, just bcm as a general idea
Erika Espinosa
02-28-2016 05:44 PM
AlexxRyzhkov
02-27-2016 11:03 PM
