O8 g35 sedan with 20x10.5 all way around
Keep in mind your OEM setup is 7.5" +45, you're going 3" wider (so it'll extend 1.5" further) and 20mm further out w/ the offset, so you're looking at almost 2.5" extended out further from where you are. Unless you're going for the slam/stretch/camber you're going to have to pull the fenders. Here's a good calculator for fitment
http://www.myg37.com/forums/tire_rim_calculator.php
I have 20x9.5 +35 in the front, and 20x10.5 +25 in the back, i had to do a pretty aggressive fender pull to fit the 10.5 but it fits now. The fronts are ok. Very minimal rubbing on mine
I have +27 all around. I can tell you it will not fit. Now, for our cars you can't roll the fenders. You have to pull them which i did and i am not happy with the job that the company did. After trying to work with them they just moved and did not take care of my situation and didn't care for the job. I got my fenders pulled out 3 maybe 4 inches to clear the wheels on my car.
laksjd84
07-24-2015 05:12 PM
