Braking Vibration Please Help!
Hello all. I have an 07 g35S sedan. A few months ago I noticed a small vibration through the steering wheel. I assumed it might be the pads so I replaced them and there was no change. The rotors look fine visually but I suspect they might be my problem. It only vibrates when braking. High speed braking (80+mph) is the worst, it's kind of violent. At very low speeds the car lopes until I let off of the brakes or stop completely. Thank you in advance for your help.
How?
How do I remove the deposits? Do they need to be machined? I didn't see a solution in any thread.
http://www.stoptech.com/technical-su...nd-other-myths
and this:
http://www.infinitig37.com/TSB/1SJ14.pdf
If the judder isn't bad and has only just started, it MAY be possible to have them ground to clean them up, but you do risk the possibility of having symptoms return. If it were me, I would just replace the rotors and be done with it. The TSB from Infiniti adds a larger splash shield on the backside of the rotor for better airflow for cooling and splash protection.
Pic here
: https://g35driver.com/forums/v36-bra...ml#post5322105
Be aware that many people developed judder symptoms even after the TSB was performed on their cars. Basically, these brakes were just poorly designed.
another vote for centric. I use Hawk HP plus pads with them. badass pads.
edit, when i first bought my g I had the shudder, seems like it was pad imprinting from the lame oem pads. I put the Hawks in and did a dozen stops per the break in procedure. shudder gone! no issues since. rotors saved!
not sure if this will work for all situations, but it was easy fix for me.
I've had my 2007 for nearly a decade now. I can tell you, changing the rotors isn't a longterm solution. The TSB? that's not the answer either. Not sure what the issue is but when it does happen, I do the procedure to bed in the brakes. It seems to work to greatly reduce judder but it doesn't go away completely. My advice? Learn to live with mild judder and periodically bed in the brakes to keep judder at bay.
the bed in procedure heats and scours off the pad imprint, but if your using crummy pads they will imprint again and the judder comes back. I had the same issue on my nissan, massive judder then switch to hawks hps on that car (more of a street compound) and judder free ever since.
doesn't have to be hawks of course but that is what i have has success with. there are many aggressive metallic and semi metallic pads out there, ferro carbon.
i'd avoid 'organic' compounds even kevlar compounds are too 'soft and gentle'
I would agree that pads that are not "rotor friendly" do a better job minimizing judder. The ceramic pads I've tried before all seem to develop judder in a hurry and have less of an effect when bedding in the brakes. I've chucked two sets of ceramic pads well before their time. So far I'm happy with the StopTech's--will try the HP Plus next on your recommendation.
