DIY: Upgrade your ugly FOB to a nicer Infiniti Smartkey
Old Mar 29, 2008 | 05:34 PM
parklife's Avatar
Ok, since I have been using a lot of great DIY tips from this forum, it is my turn to do a DIY thread.
First of all, this DIY basically just modify the remote board so it can be put inside the nicer Infiniti/Nissan smartkey remote casing. It is a little gettho, but it works.
Ok here is what you need:
-Nissan/Infiniti Smartkey fob. I got mine used of eBay for $23 including shipping. Make sure you buy the one with 4 buttons, instead of the 3 buttons from FX
-Solder and steady hand
-Electric wire
-Tape
-Double sided tape
1.Open both the old FOB and the smartkey fob carefully. I had a hard time opening the smartkey for the first time, but after the third time, it gets easier. Just try not to break anything. (including your nails like I did)
DIY: Upgrade your ugly FOB to a nicer Infiniti Smartkey-1.jpg
2.Take the old FOB board learn it and trace the board connection. Here is how I did mine.
DIY: Upgrade your ugly FOB to a nicer Infiniti Smartkey-03.jpg
3.Mark the position of the smartkey FOB switch to the old board. Precision is very important.
4.Tape the board so it will create an isolator, except for the panic button location. Since the panic button remain at the same place, you have to peal the tape using box cutter carefully. Dont scratch the board.
DIY: Upgrade your ugly FOB to a nicer Infiniti Smartkey-04.jpg
5.Pull a few copper from inside a wire. Try to get it from a thicker electric wire so you have a thicker copper wire that is easier to shape. Mine is from a 16 gauge automotive wire that you can get it in walmart.
DIY: Upgrade your ugly FOB to a nicer Infiniti Smartkey-10.jpg
6.Cut the plastic switch (I don’t know what to call this) into 4 sections.
DIY: Upgrade your ugly FOB to a nicer Infiniti Smartkey-07.jpg
Old Mar 29, 2008 | 05:38 PM
Calvin's Avatar
Overglorified Altima
pix of the final result?
Old Mar 29, 2008 | 05:41 PM
parklife's Avatar
7.This is the hardest part. Soldering.
DIY: Upgrade your ugly FOB to a nicer Infiniti Smartkey-05.jpg
Make sure you layer it with tape to prevent the copper to move around.
The panic button remains in the same place. No need for soldering.
DIY: Upgrade your ugly FOB to a nicer Infiniti Smartkey-06.jpg
8.Solder the metal battery holder from the old FOB
DIY: Upgrade your ugly FOB to a nicer Infiniti Smartkey-08.jpg
9.Put the plastic switch on top of the copper and tape it on the side. Don’t tape the black stuff. Again, precision is important if you want the button to work and have a solid button. It takes me about 5 times to adjust it until I have the solid button feeling.
DIY: Upgrade your ugly FOB to a nicer Infiniti Smartkey-09.jpg
10.Put a small double sided tape on the casing so it will hold the board in place while you put them together.
11.Put the battery in. Make sure you put the (-) and (+) side correctly
DIY: Upgrade your ugly FOB to a nicer Infiniti Smartkey-12.jpg
parklife's Avatar
12.Put everything back together. Try it and make sure you have a solid button feeling. You are done!
DIY: Upgrade your ugly FOB to a nicer Infiniti Smartkey-11.jpg
That it’s how I did mine. If you have a better way to do it, please let me know. I am not an electrical engineer so I am not responsible if something goes wrong.
Feedback is a must!
Old Mar 29, 2008 | 05:45 PM
MIA BlazinVQ's Avatar
brb getting cut
wow! thats really nice. where do you live, I'd pay you to do this for me!
Old Mar 29, 2008 | 05:53 PM
Strtsk8r321's Avatar
I've been waiting for this since the M35 came out. Thank you!
Old Mar 29, 2008 | 05:56 PM
WILLIE BEANS's Avatar
awesome .. wow dude great write up .. great job as well ..
im going to do this asap!!!!
ebay and radioshack here i come ...
woohoooooo
subscribed
Old Mar 29, 2008 | 06:08 PM
PM sent (Did you buy the key fob with the spare key or without?)
Old Mar 29, 2008 | 06:19 PM
parklife's Avatar
Yes it came with a key inside. It is used so it has some guy’s key on it. You can buy a new one with a key inside that has not been cut yet. It cost more though. And you have to bring that blank key to Nissan/Infiniti dealer to be cut and program. I prefer to use my regular key because it is PITA to remove the key from inside the remote every time you want to start the car.
Old Mar 29, 2008 | 06:26 PM
Just bought it!
Old Mar 29, 2008 | 06:40 PM
SDGeneralCounsel's Avatar
me too.
I already screwed up my backup key fob trying to do the flip key thing.
Old Mar 29, 2008 | 06:46 PM
lowrider's Avatar
Originally Posted by lowrider
Yep, the old OEM remote is a POS. It looks like those that got the new OEM remote to work are either unwilling or unable to share with us. In most threads the IP or those that achieved success in their endeavors are anxious to share. I really don't know what the deal is here. Come on guys, if you got the new remote to program, tell us how. :icon4: :icon21:
Lou
Thanks so much for the great write-up. Since the skill set needed for doing this mod lie way out of the range my abilities. I guess I'm doomed to use the old POS fob
Lou
Old Mar 29, 2008 | 06:49 PM
MikeYo's Avatar
nice mod.
Old Mar 29, 2008 | 07:30 PM
BTW hows the reception. Is it the same or worse?
Old Mar 29, 2008 | 07:36 PM
parklife's Avatar
its the same, since you don't make any changes to the antenna. While you doing it, it is also a good time to have your battery replace.
