Z1 Owners, this may be worth a try
Old Jun 22, 2006 | 01:28 PM
badbread's Avatar
Searching a elitecaraudio.com and saw this post regarding getting music on the HDD:
just use the program alcohol 120% to make images and burn them as original copies. You can d/l a free trial here http://www.alcohol-soft.com/
when you burn the image onto cd , just select "original cd" as the disc type
This may work. Has anyone tried it? If not I will try tonight when I get home.
Old Jun 25, 2006 | 10:12 AM
Slick 6MT's Avatar
It may help if you explain what you're trying to say.
Old Jun 25, 2006 | 10:44 AM
G35 Mass's Avatar
Z1's will transfer "store bought" audio from CD's to its internal HDD, but not MP3's or home-made CD's.
This is an attempted work around.
The guys on avic411.com are hard at work trying to understand the file system of the Z1. One major problem is the locking that occurs during the first boot of the Z1. When you first turn on the unit, it syncs the HDD with the unit, and the HDD becomes locked. It can be unlocked for ~$50, but it will re-lock once its put back in the Z1 and booted. Then the file system isnt anything normal, but someone somehow got to access the file system using some non MS/MAC OS, but now the audio files are in a propriatary audio format that can not be converted to / from. The reason people are trying to crack this is to be able to remove the HDD from the Z1, upgrade with a bigger HDD, then send over their entire music library from their PC to the HDD.
Old Jun 25, 2006 | 03:12 PM
jaxg35's Avatar
Does this also happen with the Alpine iva-w200 as well?
Old Jun 26, 2006 | 12:36 PM
Vegas79's Avatar
I'm able to rip homemade cds to the HD on my Z1. I've never had a problem with it. I used Nero to create the CDs.
Old Jun 26, 2006 | 01:17 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Home made...... but original format?
Old Jun 26, 2006 | 04:18 PM
patman530's Avatar
"homemade" cd's work just fine. all you have to do is burn it as a CDDA format CD, and not MP3 format. Remember to select cd-text when burning if you want text on the songs
Old Jun 26, 2006 | 06:39 PM
dubs's Avatar
As far as booting a hd with security settings is fairly easy. Get yourslef a copy of knoppix & boot your pc with it. While running this self contained cd/os, you can read any type of hd ... even the z1's.
Old Jun 26, 2006 | 10:03 PM
G35 Mass's Avatar
That was tried, did not work.
Dallsinghjr1
Sep 17, 2023 11:25 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Duffy25
Accessories
Oct 12, 2015 01:45 AM
Visionnn
Oct 3, 2015 05:16 AM
TNRocker
Sep 21, 2015 08:36 AM
