Invisicord Install Tutorial
Old Aug 10, 2007 | 02:34 AM
  #61
johnjayb's Avatar
mine came undone. make sure u stick it in there gooood
Old Aug 10, 2007 | 02:44 AM
  #62
dofu's Avatar
20 Year Member
Eh... if that ever happens, then just start stripping wires and really hardwire the thing
Old Aug 10, 2007 | 12:04 PM
  #63
JadeRaven's Avatar
If you move it around a whole lot it's likely to come unplugged. But that's if you're moving your detector constantly or something like that.
Old Nov 16, 2007 | 03:34 AM
  #64
Z2G's Avatar
Z2G
I just wanted to clarify things because I'm interested in this setup. So, I have to purchase the Invisicord AND the Mike mount from two separate ppl, right? Is Mike's mount still available? With the setup and mount, is the radar detector still easily removable for when I want to put the radar detector away in the glove compartment?
Old Feb 17, 2008 | 05:07 PM
  #65
Stealthcords's Avatar
Hi Everyone,
We're a new sponsor here at G35driver and to celebrate we're offering 30% to all G35driver members.
Rather than splicing into your factor wiring harness or running a wire from your fuse box, the SRD cord from Stealth Cords is a discrete power cord solution that connects your compatible Radar Detector to your factory powered rear view mirror.
Our sale runs into the end of Feb - so don't miss out.
https://g35driver.com/forums/accessories-vendor/201268-30-off-discrete-radar-detector-power-cords.html
All the Best!
Thank you for your support!
Old Apr 8, 2008 | 09:28 PM
  #66
Granto86's Avatar
I cant push my invisicord wires all the way into the plug, so the slightest movement of the cable turns off the radar, is there an easier way to push the wires in more? I fell like i'm trying to push them in pretty hard but they wont even budge..
Old Apr 8, 2008 | 11:06 PM
  #67
dofu's Avatar
20 Year Member
Did you get the attachment required for the G35s? The metal tip of the splicer needs to be smaller for the harness on the G35s...
Old Apr 8, 2008 | 11:13 PM
  #68
^ good point.
Old Apr 9, 2008 | 12:06 AM
  #69
Granto86's Avatar
Uhh I had no idea there were specific ones for the g35, I looked at my receipt and it was for 15.00 and looked again and saw that the g35 ones were 15.25, soo i guess I didnt.. well that sucks.. now I have to try to exchange it or get another one.. thanks alot
Old Apr 9, 2008 | 12:18 AM
  #70
hye_G's Avatar
good stuff love the cord
Old Apr 10, 2008 | 04:50 AM
  #71
jin22gt's Avatar
Is it easy to remove the V1 from the rear view mirror mount(www.countryjoycrafts.com)?
Im always in the city and need to remove the V1 from sight.
How exactly is the V1 clipped on to the mount? does it clip on like the suction cup mount?
which would you guys recommend mikes mount or countryjoycrafts.com? Is mikes mount made out of aluminun too? Does the mounts cause rattling?
thanks
Old Apr 11, 2008 | 03:01 AM
  #72
dofu's Avatar
20 Year Member
If you have a good sledge hammer and a hard surface like a sturdy metal table clamp, you can just hammer that piece down to fit... a grinder works too...
Old Jul 29, 2008 | 01:05 PM
  #73
tjlazer's Avatar
One of my wires broke near the connector! Damn I hope I can fix it somehow...
Old Oct 14, 2008 | 03:04 PM
  #74
jin22gt's Avatar
DAMN!!! Got the "SERVICE ENGINE LIGHT" on!!!
I've just installed the invisicord with the mount.
First time I've tried to install the invisicord I guess I plugged the wires all wrong, and that messed up the power in my car. The engine wouldn't turn on, it was like my car had no power from the battery. But eventually I got the plugs all right but now the service engine light is on. How do i reset the engine? and do you guys think i cause significant damage to my car? thanks
Old Nov 16, 2008 | 10:44 AM
  #75
stanfna's Avatar
Just an FIY...on my 2007 G Sedan...the power wire was brown...not pink & black.
