Invisicord Install Tutorial
Old Nov 16, 2009 | 03:27 PM
  #91
pfarmer's Avatar
Originally Posted by Muddy4DSM
I've used those crimps before and if I could hide them somewhere, then that'd be a great option. Maybe I can find some that are really small that won't look completely out of place since the back of the mirror is so visible. I wonder if Radio Shack has stiff end connectors like are use on the actual invisicord and sorta make my own. Looks like it's a trip to the 'Shack after work.
Use either heat skrink tape or tubing. If really concerned then skip the mirror and just bring another cable up hiding it around the windshield.
Also when it comes to the connector using the probe type methods of either of the commercial companies you could do the reverse. That is just get some good short needles, solder wires to them and push them in the reverse direction inside of the wire insulation.
Old Feb 22, 2010 | 07:59 PM
  #92
Z2G's Avatar
Z2G
does anyone know if the invisicord works with basically any nissan car?
Old Feb 25, 2010 | 07:07 PM
  #93
TeamSpeed's Avatar
Please email me with your details (sales AT invisicord.com) and I can supply what info I might have for your installation, thanks!
You may also visit my homepage.
Old Feb 25, 2010 | 08:31 PM
  #94
AustinG35's Avatar
The invisicord is only going to work with the cars that have the Homelink mirrors. Mike's mount only works on the G35 and 350z (they may also work on the G37 and 370z)
One point don't overtighten the Mike's Mount to the radar detector piece, it's easy to do and it will strip the plastic piece the bolts go into.
Old Feb 26, 2010 | 12:25 PM
  #95
Z2G's Avatar
Z2G
My Murano has the Homelink mirror. I think the mirror and mounting setup for all Nissans with the Homelink is the same. So, I would assume that Mike's mount would work.
Old Mar 20, 2010 | 02:03 PM
  #96
Z2G's Avatar
Z2G
For those who may be interested, the mount and the invisicord DOES work on the Murano. So, I would assume it'll probably work on most (if not all) current Nissans.
Old Jun 13, 2010 | 05:07 PM
  #97
djfarhan's Avatar
I was looking for this! Thank you!
Old Sep 9, 2010 | 09:47 AM
  #98
djfarhan's Avatar
OP, i had a question, so i have the inisicord in the mail and i just looked at the cable of the rear view mirror. i have 3 wires goin in; grey, black and brown.
The brown wire is in pin 6, and the grey wire is in pin 10. of the connector.
I know the ground will go to ground, but what about the 12 v? do you know?
Old Sep 13, 2010 | 10:13 PM
  #99
djfarhan's Avatar
Thumbs up
i just got mine done, so instead of making a new thread, i am gonna just add here:
So i got the invisicord (http://www.invisicord.com) for my 07 g35x sedan. I got the multiconnector pack for future detectors. It was 20 bucks including S&H. Here are the pics. So easy a caveman can do it! ;-P
Here is the pic of what i got in the mail. For the tips, YELLOW IS 12V, BLACK IS GROUND.
Here is the rear view mirror cable. There are 3 wires going into the connector plug. Grey, Black and Brown. The Brown is 12V, Black is Ground, and the Grey is unused in this installation. Here is what it looks like:
Here is how it is connected.
Stick the Yellow invisicord in the slot where the Brown wire goes.
Stick the Black invisicord in the slot where the Black wire goes. You can see it below. Compare it with the previous pic above:
Be careful when you stick the pins in, hold around the pins by your thumb and index finger and just slowly lodge it in. I twisted it around the rear view cable once.
For safety purposes, install this with your car turned off. Turn it on and Voila!
Thats the best place i could find for my detector, i wish i could use a mounting holder that goes around the rear view mirror piece like i have seen in some of the other installations. Oh well! Have fun! I love the clean look now. Highly recommend it for all detector users! ;-D
p.s. i know i haveta calibrate my detector..
Old Sep 13, 2010 | 10:43 PM
  #100
TeamSpeed's Avatar
Thank you for the business, and I am glad the custom made cord works well for you!
Old Sep 13, 2010 | 10:45 PM
  #101
djfarhan's Avatar
Thumbs up
Originally Posted by teamspeed
thank you for the business, and i am glad the custom made cord works well for you!
:jamin:
Old Aug 18, 2011 | 09:16 PM
  #102
Illuminati's Avatar
Sorry to bump this old *** thread but I just ordered a Invisicord and a 9500ix and my car doesn't g35 doesn't have a homelink mirror. Is there anything else remotely close that I can tap into?
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
