2006 Sedan...where to TAP RCA for 500/1??
Old May 18, 2007 | 10:35 AM
CFaber's Avatar
I've searched and searched...to no avail. Lots of info on the coupe install, however could find anything specific to sedan.
Where exactly should I splice a set of twisted RCA's to feed my 500/1 sub amp. It's currently getting signal from the two-wire harness directly at the subwoofer, but I'm told this is improper, as it's "after the bose amp".
Could somebody please clarify where a Sedan owner needs to tap before the Bose amp for a sub signal? Wire color/location, etc would be greatly appreciated.
Chris
Old May 18, 2007 | 08:30 PM
CFaber's Avatar
can anybody answer this?
Old May 20, 2007 | 12:09 AM
Gilley's Avatar
It's basically the same operation as a coupe, except that the Bose amp is located under the rear window in the trunk, behind the liner.
Old May 21, 2007 | 11:31 AM
CFaber's Avatar
Same as the coupe? The coupe does not have a dedicated subwoofer with it's own amplifier. I guess I don't see the similarity.
Old May 21, 2007 | 01:23 PM
amthar's Avatar
The coupe has two tweeters and two woofers in the front, same as the sedan. The coupe has two rear side panel speakers, much like the rear door speakers in the sedan. The coupe has two rear deck speakers, these are instead of the rear subwoofer in the sedan. That's pretty similar.
FL+ White
FL- Black
FR+ Green
FR- Red
LR+ Brown
LR- Yellow
RR+ Blue
RR- Pink
That should get you started. With a voltmeter and the fade/balance controls you should be able to locate any wires you need regardless.
Old May 21, 2007 | 03:25 PM
CFaber's Avatar
FL+ White
FL- Black
FR+ Green
FR- Red
LR+ Brown
LR- Yellow
RR+ Blue
RR- Pink
Thanks.
I guess, my question is, do I tap into the rear speaker wires to feed my 500/1 for the my sub?
Old May 21, 2007 | 03:37 PM
amthar's Avatar
Front or rear, it doesn't matter. And seeing as how you are using a 500/1 you don't need to use a LOC, so good call on using the twisted RCAs.
Old May 21, 2007 | 03:41 PM
CFaber's Avatar
Perfect, thank you. I wasn't sure if tapping the rear speaker would effect the signal (frequency range) sent to the amp/sub.
I've already tapped the fronts for my 300/2.
Chris
Old May 22, 2007 | 10:17 AM
Gilley's Avatar
I would tap into the rear speakers so you can use the fader to help adjust the bass level relative to the front speakers, even with the JL bass ****.
Old May 22, 2007 | 12:32 PM
CFaber's Avatar
good advice, thanks.
Old May 22, 2007 | 01:45 PM
ttrank's Avatar
Grocery getter
+1, use the rear speakers. That should give you the range you need.
mbe32
Nov 13, 2015 11:09 PM
alessandro
Oct 8, 2015 09:29 AM
Patrick Bovee
Oct 1, 2015 10:42 AM
JustinMKN1
Sep 18, 2015 03:40 PM
bigmike
Sep 17, 2015 01:58 PM
