a/c wont turn off and radio not working.
Old Aug 23, 2010 | 10:01 AM
  #121
zx14kawboi's Avatar
Originally Posted by Wrathernaut
^^ WTF - same price sedan or coupe, "god" and all of us know that replacing with aftermarket works just fine.
x 10000000000000000000000000000000000000000000
Old May 17, 2011 | 04:24 PM
  #122
Wiseman's Avatar
Originally Posted by gpepper
I had the same problem everyone else seems to be having. In Atlanta the guy to take it to is Nahed Abdulnabi @ Electronics Master Repairs on
Pleasant Hill Road in Gwinnett County (678) 957-0686.
He upgraded the power supply and had me rolling in a few hours for $300.00 with warranty.
GC
Bringing this thread back from the dead. Thank you so much for the above info. Electronics Masters took 2 hours to repair, $300, lifetime warranty, even replaced my clock light . DONE DEAL. Sad part was there were 4 other broken G's in the parking lot. This guy does 15-20 a month. We keep him in business lol.
Old May 17, 2011 | 04:50 PM
  #123
vp-g's Avatar
^^did he tell u what the problem was?
Old May 17, 2011 | 05:04 PM
  #124
gpepper's Avatar
it has been a while so I am not sure I recall. I think he said the power supply was never strong enough from the manufacturer and it was only a matter of time before it would need to be repaired. Mine has been going strong ever since. No issues. He replaced the light in my clock too. Thats funny!
Old May 17, 2011 | 06:56 PM
  #125
Wiseman's Avatar
^^Yep the power supply for the AC controls & radio was replaced. Mine was flickering on and off for a few weeks before it finally went dead. Had no radio for 3 weeks before I stopped being lazy and called him up.
Old Jun 27, 2011 | 11:20 AM
  #126
DARLLL's Avatar
Try wiggling the key a little bit(anticlockwise) when the problem starts ...it should fix itself and reset......worked for me..
Old Jun 14, 2012 | 10:07 PM
  #127
SooWoo's Avatar
i changed my unit, i bought a replacement dash kit and added a double din, everything works EXCEPT
for my A/C!!! .... when i put the rear defogger on the A/C light turns on automatically (normal), but when i want the A/C by itself its not working ??? i read about the problem for days, and alot of ppl saying to replace the kit and i did .. and its still not working .. someone PLZ HELP!! its too hot
im assuming its an electrical problem.
Old Jul 9, 2012 | 02:36 PM
  #128
swoo35's Avatar
Can someone conclude these 9 pages.. I've read through some of them and there are lots of prices and methods on how to fix this issue. I was wondering what the best possible solution to this issue is??
Old Jul 9, 2012 | 08:01 PM
  #129
Wrathernaut's Avatar
Gentle Manne of Leisure
Aftermarket radio and trim kit. Prices for the conversion start at $180 and go up to whatever you're willing to pay.
Old Jul 22, 2012 | 01:18 PM
  #130
RastaManMax's Avatar
Before jumping to this conclusion, my 03 coupe had this same problem last night where the AC was frozen to on and the radio stopped working. Just disconnected the battery and pulled the stereo fuse by the battery and reconnected everything and it seems to be working again.
My fuse did seem oddly easy to come out and a bit higher up than all the rest so i'm hoping it was just too loose for whatever reason. Either way, i'm going to start getting a working knowledge of Wrather's thread and other double din options in case it does creep up again.
Old Aug 14, 2012 | 11:59 AM
  #131
C-Dub's Avatar
So I ran into this issue yesterday for the first time in my 06 Sedan. I was stressing out but I found this post on youtube:
Just removing the stereo fuze resaolved my issue...for now. I also had the issue where my a/c wouldn't cool unless I turned it down to 60 degrees. The video tells you how to fix that too. Hope it helps someone else!
Old Oct 17, 2012 | 12:10 AM
  #132
claudej's Avatar
claudej
I own a 2003 G35 Coupe and I also had problems with my air conditioner and radio as others have described. I took my car to John Huang at XW Electric Co. in El Monte California. He charged me $200 and completed the repair in approximately 45 minutes. He can be reached at (626) 757-0465, 3608 Arden Dr. Suite J, El Monte, CA.
Attached Thumbnails a/c wont turn off and radio not working.-teardown.jpg
Old Dec 28, 2012 | 08:38 PM
  #133
Ampvqfanboi's Avatar
Well... Taking this thread back to the top lol i need help
My ac buttons nor seat heaters dont work AT ALL its 25 degrees outside and when i go to press any ac control button nothing happens my radio works fine and i have power going to all of my center console hints the whole console lighting up. I would rather not take it into the dealership because i dont want my pockets drained i hope its a simple fix. What could be the issue?
Old Feb 17, 2013 | 05:46 PM
  #134
DanielleDiva's Avatar
I'm about to go in on this circuit board issue... My car is going on its 3rd replacement radio. I'm seriously considering going aftermarket if :
I can find a screen that will match the orange interior
a dash kit that doesn't have rubbery stupid ac control buttons,
AND being positive there is a way to hook up the stereo controls to the aftermarket player.
anyone with suggestions on those three things I would love to hear.. NOW back to the ster'eo.. its an 03 sedan, had the "voluntary campaign recall" completed in 03 at the local Infiniti dealership. worked for about 60k miles then same issues all over again!! At that point I brought the car to a body shop that I knew a few people, and got the circuit board replaced. that also worked for like 40k miles (yes shes got 135k :-/ ) I did a ton of research and someone posted a diagram of the circuit board with which resistors might need resoldering. SO a few weekends ago I used a youtube vid to take my car apart (piece of cake btw) I got the radio out, then without any guidance kept taking it apart until I got to the circuit board.. I was expecting rust or some sort of damage, but it looked brand new. I noticed a teeny bit 0of yellow stuff that looked like corrosion around a few resistors so I just cleaned that off and resoldered a little bit hoping that was the issue.. after I put everything back together it worked!!! everything worked perfectly! now.. 3 weeks later damnit it went out again. theres no pattern whatsoever, speed, turns, humitidy, weather, volume, heat, how long it sits or drives, NOTHING no pattern whatsoever when it acts up so I can not narrow down the problem!!! I work two jobs and pay all my bills and obv am not trying to spend a fortune!! CHEAPEST, CUTEST, PERMANENT FIX?!
Old Feb 18, 2013 | 05:37 AM
  #135
Victorious360's Avatar
I found a solution to the radio and A/C issue! http://www.amazon.com/gp/aw/d/B001JT1FGY. This fixes the ac issue and allows you to install a radio of your choice.. Hope it helps.
Posted from G35driver.com App for Android
