JL 500/1 and 10W6
Old Apr 10, 2008 | 11:26 PM
collin's Avatar
JL 500/1 and 10W6
I know all cars are different. Curious if this will hit pretty hard or if I should do 2 10W6's in the Zenclosure box?
reason I ask is I had a Rockford P10002 Amp powering 2 Eclipse 10" subs in my truck and it didn't hit terribly hard...mostly because they fired into the cushion of the back seat.
Old Apr 10, 2008 | 11:44 PM
pattyskin's Avatar
I got a 10w6 and a 500/1 in a 4080 fiberglass enclosure. It sounds amazing. It doesn't hit as hard as my 2 10's in my neon did but it is a single sub so yeah, good bet to go with this.
Old Apr 11, 2008 | 09:22 AM
Meatshackle's Avatar
Deep Sea Moderator
I started with one and it was plenty.......at first. I eventually wanted more so I got another and a passenger side 4080 box. I can't give a review of that setup yet because it's not installed yet.
Old Apr 11, 2008 | 09:24 AM
Hi-TechG35's Avatar
Zenclosure boxes are good for the money but the airspace will not support the JL Audio W6's.
Old Apr 11, 2008 | 03:02 PM
1trueG's Avatar
I have a single 10" w6 and the 500/1 and I am satisfied with it. At first, I wasnt satisfied, but after setting the amp up correctly with the digital multimeter and the sound test cd, it was a huge difference. Like said above, the zenclosures box wont work well with two w6's, but if you go with a single w6, the single enclosure from them will work perfectly.
Old Apr 13, 2008 | 10:49 PM
mpapers's Avatar
you mean if you put 2 w6s in that box? The .8 airspace should be perfect for 0ne..
Old Apr 13, 2008 | 11:18 PM
collin's Avatar
yeah i am thinking the single 10" zenclosure box with the space to mount the amp. Bought the 500/1 amp today. Might have found a deal on a W6.
Also just noticed my factory headunit is dead (cd error fo). so I am gonna be on the look out for a double din
Old Apr 14, 2008 | 07:44 AM
Gilley's Avatar
It depends on if you need your back seat passthough too. The Zenclosures box will block the passthrough while the 4080 boxes won't.
Old Apr 14, 2008 | 07:52 AM
caelric's Avatar
Originally Posted by pattyskin
I got a 10w6 and a 500/1 in a 4080 fiberglass enclosure. It sounds amazing. .
Same setup as you, hits loud and hard, still leaves me with the pass through, and plenty of trunk space.
See my .sig for pictures.
broke_as_ajoke
Nov 6, 2015 11:49 PM
ax11
Jul 16, 2005 04:47 PM
IntensitGy
Feb 11, 2005 08:39 PM
G35coupe19
Aug 18, 2004 09:01 AM
G35Kid
Jan 22, 2004 09:18 PM
