SAT antenna mounting question
Old May 25, 2004 | 09:37 AM
pharmboy's Avatar
For those of you who installed their own SAT radio, how did you mount the antenna on the rear parcel shelf? I don't think the magnet alone will secure it during "spirited" driving. Ideas please!!!
Old May 25, 2004 | 11:00 AM
Noremac's Avatar
Re: SAT antenna mounting question
First, which antenna are you talking about?
If it's the one that came with the OEM kit (the ugly mouse on steroids), then simply applying a piece of adhesive velcro (the hook side) to the bottom will hold it pretty good on the deck carpet.
If you buy one of the newer, smaller antennas, these can be hidden underneath the carpet, etc.
<font color=blue>'04 G35S 5AT, Black Obsidian/Willow, Prem/Nav/Sat</font color=blue>
Old May 26, 2004 | 05:47 PM
djrobx's Avatar
I second that. I trapped my Sirius "steroid mouse" with a small piece of hook velcro, it's not going anywhere. Even before I put the velcro on there it really didn't move all that much to begin with, it's pretty heavy.
-- Rob
Old May 26, 2004 | 06:31 PM
h2omaan's Avatar
Sat antenna w/spoiler!!!!!!!
if anyone has a spoiler, you can put the small XM antenna's under the spoiler and it works perfect. The antenna's will go through anything but metal. Just take the underside liner of the trunk lid off and there will be a gromet for the brake light wire of the spoiler. remove the gromet and take a pair of tin snips (metal shears). and make the hole bigger. put antenna through hole, will stay in place with the magnet on bottom. reinstall grommet in hole (yes the hole is bigger now but just do it) then silicon around gromet and hole. run wire through trunk lid and factory grommet that goes into car, reinstall panel and wala all done and no visible antenna. now that is the pimp SH@T
<P ID="edit"><FONT class="small"><EM>Edited by h2omaan on 05/26/04 03:56 PM.</EM></FONT></P>
Old May 28, 2004 | 03:19 AM
Ca_Kid's Avatar
The TERK XM3 antenna is currently a stealth placement within the rear brake light housing. This location, however, does cause dropouts.
This link shows the picture of the rear brake housing.
http://www.xmfan.com/viewtopic.php?t=7117&highlight=
03G35c/C_Blue/Willow/5AT/Prem/Splash/ SteetPilot 2610/V1/SAT/XM/Borla True Dual Exhaust/Gialla Grille/Z Intake/Dynamat Door Kit.
Old May 28, 2004 | 08:30 AM
Skeeter's Avatar
Does anyone know if the XM antennas and the Sirius antennas the same. I hate the steriod antenna and was wondering if the Sirius antenna that is installed on the Mercedes Benz can be used with the XM systems?
Old May 28, 2004 | 10:27 AM
Noremac's Avatar
The XM and Sirius antennas are not the same. If you want a really small XM antenna, consider the Terk XMicro.
Old May 28, 2004 | 10:35 AM
Skeeter's Avatar
Thank you for the information
Old May 28, 2004 | 02:42 PM
Ca_Kid's Avatar
As Noremac pointed out, Terk offers a micro antenna that is about the size of a fifty cent piece. Can be obtained from Circuit City for $30. However, you will need a converter for the single wire antenna to our double antenna connection on the Clarion XM receiver. That converter can be obtained from http://store.myradiostore.com/blxmansp.html
It is a Blitzsafe XM-1DAS Antenna Splitter for $30.
Old Jun 4, 2004 | 11:14 AM
Skeeter's Avatar
Are you getting droputs more frequently? The dealer told me that antenna is a low profile antenna which may cause more dropouts than usual and the steriod antenna is better because it is high profile.
Old Jun 4, 2004 | 12:06 PM
al503's Avatar
I just installed the terk micro and I do get more dropouts than the huge antenna that comes with the tuner.
Old Jun 4, 2004 | 04:47 PM
Ca_Kid's Avatar
I have no experience with the Terk Micro Antenna, as I have not purchased it yet. Do have the Terk XM3, and it did not cause any more dropouts than the big-big Clarion antenna that came with the XM radio. The dropout problem is caused by my placement within the rear brake housing. The dropout frequency is quite infrequent and within tolerable limits.
The reason Infiniti insists on the large antenna is that it is cheaper antenna, and when you are purchasing thousands of antennas, it is a vehicle cost consideration. As the antenna size diminishes, the cost of manufacturing the item goes up.
tal1412
Nov 28, 2022 09:25 AM
snic09
Nov 8, 2017 01:46 PM
Hawk196
Sep 22, 2015 02:51 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Mac8008
Aug 4, 2015 09:19 PM
