Post pics of your double din setup
Old May 30, 2012 | 09:56 AM
  #466
RicoG35x's Avatar
nice!
Old Jun 22, 2012 | 07:43 PM
  #467
van_driver's Avatar
how much do these Double din conversions approximately cost including installation? Did you guys buy all your parts online? thanks
just want to make sure, is this everything I need to get a double din conversion set? does the price look reasonable to you guys?
Old Jun 22, 2012 | 08:09 PM
  #468
04G35NYC's Avatar
Double din face/ac controller go for $250 to 270, Headunit, harnesses so you dont have to use your OEM $10, your own install Free, i can tell you pretty much what to do to install it and its pretty much easy to do.
Old Jun 22, 2012 | 08:15 PM
  #469
JuiceDogg's Avatar
Depends on if you want to keep your steering wheel controls or add an aftermarket amp, subs, door speakers. Do you have a Bose system or factory navigation because that will determine what dash kit you need. Do you want a metra dash kit our an OEM dash kit. You still needed a double din trim ring to make it flush. Email me I can help you out the best I can I just did mine about 4 months back.
Old Jun 22, 2012 | 08:23 PM
  #470
van_driver's Avatar
Yes it is bose system without navigation.
This is the touch screen pioneer one with a rear camera as well
http://www.crutchfield.com/app/cart/...3&emKey=789563
and this is the one which is about half the price
http://www.crutchfield.com/app/cart/...3&emKey=789554
just a little confused as to which one would be more beneficial. I will probably get it installed as my technical skills are not good!
Old Jun 23, 2012 | 01:06 AM
  #471
Wrathernaut's Avatar
Gentle Manne of Leisure
As cheap as $150-200, as expensive as you want.
Cheap: Metra kit and a ~$50 radio combination from crutchfield.com.
Old Jun 30, 2012 | 01:20 AM
  #472
Aztec's Avatar
not a DD,
Old Jul 4, 2012 | 03:30 PM
  #473
paclypse71's Avatar
Factory Navigation Screen Housing Added To Non-Nav 2006
Here's the setup I installed a few years ago. I added the factory navigation screen housing and controls to a Non-Nav system using the the Electrical section of the Infiniti Service manual. My diagram of the wiring is included in the photos.
I removed the factory screen and installed an Alpine Touchscreen, which fits almost perfectly. As shown in the diagram, the operations of the navigation screen motor and the navigation switch illumination were restored by splicing into the A/C control wiring harness.
I wasn't able to find a Navigation version of the JDM Double Din Finisher at the time of installation, so the extra height of the non-Nav finisher required some modification that the installer wasn't able to get quite right.
I added switches on the side of the center console to control my front and rear license plate frame cameras. The upper switch turns the front bumper camera ON and OFF on the upper screen for more precise parking. The lower switch toggles the rear-view camera between ON and REVERSE on the lower screen as needed.
-Alpine IVA-W505 Double Din Head Unit
-Nissan 27500-AC500 A/C Control Module (DUAL button and LED soldered from original board)
-JDM Double Din Finisher
-Alpine TME-S370 Touchscreen Monitor with Alpine NVE-M300 Navigation
-Alpine KCA-SC100 Sirius Control Interface
-Sirius SC-C1 Sirius Controller
-Alpine PXA-H100 Imprint Module
-Alpine KCE-400BT Bluetooth Interface
-PAC SWI-JACK Steering Wheel Control Interface
http://photobucket.com/paclypse71
Old Jul 9, 2012 | 03:42 PM
  #474
adman101's Avatar
http://www.crutchfield.com/p_113DDX3...od-DDX319.html
my Bose stereo in my 04 isnt playing sound, thats it, so if i go with this DD alls i need is the PAC REOM NIS2, antenna adaptor and say the metra kit right?
Old Jul 9, 2012 | 08:14 PM
  #475
You'll also need the steering wheel adapter (Metra Axxess ASWC).
Old Jul 11, 2012 | 10:45 PM
  #476
islandtuner242's Avatar
i'm looking for the double din kit that keeps the factory buttons because i HATE how the Metra kit looks the buttons seem cheap i prefer the factory buttons.............. i drive a 03 coupe
Old Jul 12, 2012 | 03:08 AM
  #477
The reputable sources I know of are all on my shopping/resource list that's sticky'd at the top of this forum. Just expect to be out over $300 for it. (Money well spent, IMO)
Old Aug 16, 2012 | 11:39 AM
  #478
yusoslo's Avatar
I see alot of you guys are running the Pioneer 4400. I really like the clean look of the Sony 72BT for $350. What is your thoughts on the two?
Old Aug 16, 2012 | 05:09 PM
  #479
The 72BT is is pathetically slow and laggy. I could never live with it every day. For $350, you're looking at the Pioneer 3400BH, which is a fantastic unit. Bluetooth, HD Radio, very good interface.
Just watch this video. THere's like 3 seconds between every tap of the screen and the result:
Just look at it from 0:14 to 0:34. That's how long it takes them to get from playing one song by an artist to another.
Old Aug 16, 2012 | 05:32 PM
  #480
blazeplacid's Avatar
if sound quailty is your goal the sony is a better choice than the Pioneer.
Out of the box with no adjustments the Sony unit I had sounded better.
The Sony also has time alignment.
there is some lag but I delt with it
sound quality > extras
for me
