Do our doors leak when it rains?
Old Feb 11, 2009 | 03:35 PM
TroysG's Avatar
jbweld is a lil extreme but it'll do the job
Old Feb 11, 2009 | 03:51 PM
releasedtruth's Avatar
I siliconed after I cut into the grommet behind the battery. Works fine, only 4G though
Old Feb 12, 2009 | 01:19 AM
Mr. Samster's Avatar
yea i know after i bought it.. i was like y did i buy it, lol i just bought some silicone so im going to use that and return the jb weld.
Old Feb 12, 2009 | 12:17 PM
The Stimulation's Avatar
Where is the exact location of the leak? It doesn't rain too much in Cali, but when it does, it comes down hard most of the time. I don't want to have to go through a new set of 10's each time it rains.
If it is from above where the door panel meets the window, I was thinking maybe some weather stripping could solve the issue.
Old Feb 12, 2009 | 01:42 PM
TroysG's Avatar
that's likely where it would come from... I don't think it's an issue if you have a newer car. but if you've got like an 03/04 it could become a bit of an issue - aging weatherstripping just won't seal like it did 5 years ago.
Old Mar 6, 2009 | 06:59 PM
Took the door panel apart today and yes, it definitely leaks. I could see some dirt and a little splashage on the bottom below the speaker so it may come from the bottom... Awesome, eh? And I have an 06 in Tucson!
Old Mar 9, 2009 | 10:57 AM
After opening the driver's side up, definitely not a good thing. Whole panel was dirty, top and bottom. Window motor covered in dirt. Should I be concerned? Speakers are protected for the most part, but this seems like a major problem.
Old Mar 9, 2009 | 01:19 PM
TroysG's Avatar
I've seen a lot of cars with leaking doors... generally it's not a huge problem... if it's retaining a lot of water you will have a MASSIVE problem
Dallsinghjr1
Sep 17, 2023 11:25 AM
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
hrdwirk1
Oct 2, 2015 06:34 PM
vamarris
Sep 26, 2015 12:56 PM
