Preparing to install Pioneer Double Din, Want to make sure I have everything
Old Oct 3, 2009 | 04:26 PM
hye_G's Avatar
Exclamation Preparing to install Pioneer Double Din, Want to make sure I have everything
Hey guys so im prepping to install my new Pioneer double din i just want to make sure I have all the parts I need to properly do the install.
Headunit - Pioneer AVH P4100-DVD
Nissan Diversity Antenna
Metra 70-7551 Harness
PAC SWI-PS
JDM Double Din Kit w/ AC Controller
only other thing i can think that i might need is some sort of "relay" to do the DVD bypass and also ive never done wire crimping or splicing and tools i need. Any help would be great, ie DIYs or tips, ive done a lot of searching and havent found a really good DIY for a double din install with pics. Thanks a lot guys!
Old Oct 4, 2009 | 02:10 PM
mattyjman's Avatar
have you looked at the stickies? -- should have plenty of info there....
I have never done the DDin install, but from what I have read here you should have everything your supposed to.
As far as crimping...it's real easy, go to Home depot, buy some crimp caps and a wire crimper/stripper....should be good to go...
Old Oct 4, 2009 | 05:59 PM
hye_G's Avatar
yea, might have to go check out the depot
Old Oct 5, 2009 | 04:55 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
You're probably going to need a trim ring to avoid a gap in the JDM kit.
Here's the way I did mine:
https://g35driver.com/forums/audio-v...ll-w-pics.html
And yeah, #1 sticky for this forum:
https://g35driver.com/forums/1178565-post6.html
Very good 05 coupe dash removal DIY.
Old Oct 9, 2009 | 04:14 AM
hye_G's Avatar
so should i just use foam, my deck actually came with a thin plastic trim, i think
Old Oct 9, 2009 | 05:47 AM
Joaquin03's Avatar
Staff ALUMNI
good luck on the install, I might not have had the greatest luck installing my Pioneer DD on my own...
Old Oct 10, 2009 | 08:38 PM
The kit I used to fill the gap cost all of like $10.
If your system came with a proper trim ring, that's the best way to do it, unless it isn't big enough.
Old Oct 10, 2009 | 10:31 PM
hye_G's Avatar
also just picked this up http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=380142208444&ssPageName=STRK:MEWNX:IT
Old Oct 11, 2009 | 01:58 AM
iTzTeddy's Avatar
Hey I am too, I'm getting the Pioneer AVH-3100DVD. Of course I don't have much yet but I'm getting:
1. Double din HU
2. JDM double din kit
3. Nissan Antenna
4. Harnesses
5. Steering wheel control
Please post pics asap once you get it install. Are you DIY or pro?
***does all hu that have dvd has that option of shutting down when car is in motion? I might need to get that too
Old Oct 12, 2009 | 02:23 PM
hye_G's Avatar
im pretty sure u will need a bypass kit if you want to use the dvd player in motion. im not sure, i might attempt the install by myself or just take it in.
Old Oct 13, 2009 | 04:16 AM
No real kit to do the dvd player in motion mod. Just search around on the HU you put in.
Old Oct 14, 2009 | 01:33 PM
ridinDirty's Avatar
Hye_g I am planning on installing the same unit on my 2004 w/ bose & no navi. I have all the parts ordered and just waiting to get them in the mail. Let me know if you have any problems or anything I need to look out for on the install. I plan on doing this install myself. Lookin forward to gettin it in my car!
Old Oct 15, 2009 | 01:26 AM
hye_G's Avatar
will do, i got all my stuff, just need the time to put it in. im thinking im gonna wire everything (harnesses, bypass, etc) before i tear everything apart so when i take the headunit out and put the pioneer in, itll be plug and play essentially.
Old Oct 15, 2009 | 02:40 PM
iTzTeddy's Avatar
You guys get your HU off crutchfield? I;m getting the 3100 and they are giving out massive free stuff with free shipping for 449. That is the best place to buy ur HU if its going to DIY. Me on the other hand have no intentions with ****ing with anything in the back so i might it to the shop. I calculated the amounts of the items and the installation together. Looks like it is going to be 1k, if you can please post up a DIY on that or PM me, if its easy enough i might DIY and save 250 on installation
Old Oct 15, 2009 | 06:23 PM
hye_G's Avatar
i actually ordered all my stuff through best buy since i work there. and install will be done by me. so well see how it goes.
