crossover mounting location
Old Dec 22, 2009 | 03:51 AM
RADRaze2KX's Avatar
what's the best place to mount a crossover into the door for component speakers? is it right next to the woofer? I see pics occasionally when doing sporadic surfing of this site, but my intentional searches have been fruitless for pictures I ask because a friend and I were outside drilling holes and such, mounting all the lovely hardware i got from Cadence today, and when putting the door panel back on, realzied it didn't fit -_-" we're both moderately sick but I have no sound in my car right now and drive ~150-200 miles a day ._.
Old Dec 22, 2009 | 11:33 AM
sufu's Avatar
if it doesn't fit in the doors, why don't you just route the the xovers to the trunk?
Old Dec 23, 2009 | 02:50 AM
RADRaze2KX's Avatar
because i'm using thick speaker wire and don't want to route 4 cables. i tried right by the speaker but it hits the lock/window switches... i'm thinkin near the edge of the door by where the VIN/Paint info is... any other feedback or pics??
Old Dec 23, 2009 | 05:52 AM
RADRaze2KX's Avatar
I found a place to mount them ... I'll post pics later, I just locked my @#^! keys in the car and had to shell out a buckfiddy to have the door pump-wedged and the lock opened ... curse me and my half-asleep idiocy.
Old Dec 23, 2009 | 10:49 AM
blazeplacid's Avatar
take the door panel and try to mount them in the pocket
ideally you would want to mount them close to the speaker but its ok to mount them in the trunk
Old Jan 2, 2010 | 04:21 AM
Meatshackle's Avatar
Deep Sea Moderator
Mine are towards the rear of the door about level with the arm rest. I shaved a little bit of the foam on the inside.
You definitely don't want to wire your crossovers for the doors in the trunk. That would be a lot of wire and a pain.
Old Jan 2, 2010 | 10:30 AM
liche's Avatar
There should be a rectangular indent (pocket) at the bottom rear corner of the door where they can be screwed directly to the door. At least in the Sedan there is.
Old Jan 18, 2010 | 01:28 PM
EGDgyDor's Avatar
Where to put crossovers...
I am looking to do the same with my '03 Sedan. I pulled up the carpet on the driver's side and found a long recessed piece of styrofoam. I figure I can cut that and put the crossover in the recess of the floor board. I'll double wrap it in plastic and cover it with a hard material to play it safe. The passenger side is the same but more narrow (asimetric floor boards ?). If your crossovers are no more than 3 to 4 inches wide - they should fit. Good luck.
Jessica Ayoub
Oct 17, 2015 02:01 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
boostelevator
Sep 9, 2015 05:56 PM
pasjr1972
Sep 1, 2015 10:17 PM
