I turn my car on and there is no sound from the speaker's?
Old Feb 11, 2020 | 11:25 PM
  #91
05_SkylineSedan's Avatar
20 Year Member
It's easier the 2nd time!
Old Mar 17, 2020 | 11:47 AM
  #92
romel 4life's Avatar
Infiniti g35
My g35 sedan is having a radio problem, it only cuts on when the vehicle is cold and after a minute its just fades out, there is still power to the radio it's just that there is no sound coming from the speakers and the speakers work. What should I do
Old Mar 17, 2020 | 03:24 PM
  #93
telcoman's Avatar
Veteran: Army
Test the speaker wiring connections in the harness.
Unplug the wiring harness from the radio and put a test tone on the harness and trace the tone with a test probe to the speakers
You can purchase both at any Home Depot store
Old Mar 17, 2020 | 08:33 PM
  #94
Scorpi0's Avatar
Sounds like a bad amp. Either in your head unit or your Bose amplifier in the trunk. Do u have the Bose sound system?
Old Dec 2, 2020 | 08:40 PM
  #95
Infiniti g35
I looked and I don’t have a amp in the trunk
Old Jul 29, 2021 | 04:31 AM
  #96
HeyZeus420's Avatar
2006 G35 coupe premium
I have the same problem as the OP... I have read the post and done my research and at this point I'm convinced I need to replace the amp I've been informed by the local shop I have to go to Bose to get the amp... They want $850... If somebody could tell me where I can find a plug and play replacement for the Bose amplifier I would be eternally grateful!!!!
I just want it to make decent sound it doesn't have to be super fancy but hopefully less expensive than the OEM...
I also do not care if the audio for the nav system works or not it kind of irritates me to be honest
Last edited by HeyZeus420; Jul 29, 2021 at 04:34 AM. Reason: I do not care if I retain the functionality of the audio portion of the nav system
Old Jul 29, 2021 | 05:46 AM
  #97
Scorpi0's Avatar
Im assuming u still have the original head unit?
Your best option would be to find a used OEM amp that someone is selling on ebay.
Old Jul 29, 2021 | 12:23 PM
  #98
HeyZeus420's Avatar
Website for amps found
https://www.cd4car.com/infiniti-g35-...-225-watt-amp/
I just ordered one from that site
spykegtp
Mar 5, 2021 07:59 AM
lexstart
May 8, 2013 01:40 PM
jeanzpaul
Aug 26, 2012 02:20 PM
