NAVBOX TEST RUN COMPLETE
Old Mar 16, 2005 | 02:20 PM
  #166
Benzito's Avatar
It's Not an old version they all look like that , What colors are the wires that go to the screen?
Old Mar 16, 2005 | 04:20 PM
  #167
rrpnow's Avatar
how do u c the pics? the links dont wrk for me... ahhhhhhh
Old Mar 16, 2005 | 04:50 PM
  #168
Benzito's Avatar
What pics ? LOL you mean my sig. It got messed up when the site chnged over to the new hitech version, There all better now , Didnt have any g35 stuff on there anyway ony Buick GN's. Im working on a drawing that should help you guys with the installation.
Old Mar 16, 2005 | 07:39 PM
  #169
Wanchu83's Avatar
thank you so much... I hope you finish it soon ^^
Old Mar 17, 2005 | 07:20 PM
  #170
slizzap's Avatar
Here's the instructions I got with mine.
http://slap.gotdns.org/NavBoxInstallDoc.doc
Old Mar 17, 2005 | 10:12 PM
  #171
Wanchu83's Avatar
thanks alot. I hope the install guy can figure this thing out for me. hehe
Old Mar 18, 2005 | 12:21 AM
  #172
Wanchu83's Avatar
Ok, I sort of get the diagram. Well, my final question today is..
I bought Streo audio/video cable, mono to mono splitter, audio Y-cable(so I can put audio to SAT1 and 2).
Question is Where should I install my NAVBOX? under the armrest? middle of the backseat(where the first-aid kit is)? Any suggestion?
Old Mar 18, 2005 | 01:08 AM
  #173
slizzap's Avatar
I have an 04 coupe. I took out the back seat and cut the bottom plastic off the center console piece. Then I mounted the box to the floorboard. The seat fit right over it and you can access the box by lifting up that little panel. Gives you perfect cable length to both the navigation unit and the trunk.
Old Mar 18, 2005 | 09:47 AM
  #174
Benzito's Avatar
Thanks for posting that Slizzap, I havent had the time to come up with the schematic, I also mounted mine under the rear cup holder , Any other place may give you problems with cable length.
Old Mar 18, 2005 | 11:28 PM
  #175
Wanchu83's Avatar
can you tell me where you guys grounded the wires?
I know two uncovered wire has to be connected to NAVcase as direction says, but where you guys ground other two? picture will be great.
And do you guys have picture of where switch is installed? do we have to ground the swtich also?
Sorry I am newbie about the wire
Old May 27, 2005 | 04:49 PM
  #176
eddie914's Avatar
Question
Originally Posted by dollar99
the navbox comes with the cable to directly plug into the xbox. Then the box itself has 2 RCA audio outputs and 1 extra video output.
The PAC AAI-NIS has grounded latched outputs. We can use these outputs to trigger the NAVBOX to select the NAV or Xbox. This means that we can use the steering wheel controls to change the video.
Channel 1 = XBOX
Channel 2 = Nav
_________________________________
430+ Horsepower at the crank.
I just ordered the PAC Navi-tv unit(forgot what's the model number ) I want to do the same thing that you did which is using the SAT buttom to switch on the Navi-TV device. since I don't know much about wiring thing(but I really want to do it myself ). can you plase give me some instructions on how to "tap" the ground wire to the Navi-tv box insteat of using the on/off switch? There's 2 wires attach to the on/off switch. should I just cut it out and "tap" the ground one on the PAC_AINISS ground output?
Old May 29, 2005 | 05:03 PM
  #177
CKwik's Avatar
I'm not sure how the Navi-TV unit you are using is wired, but with PAC-NIS, when you select a SAT channel(1 or 2) it will provide a ground to it's corresponding switching wire. If the Navi-TV box uses a ground output to switch the video between the Navi display and the external video display, you attach that signal wire to the PAC-NIS switch ground you want. A bit of warning though, test your ground output switches on the PAC-NIS. Only one of mine actually switches. The other provides a contant ground. Mine may be an isolated issue, but better safe than sorry, espectially if the PAC-NIS is mounted where it is hard to access.
Old May 29, 2005 | 06:57 PM
  #178
Lamont Coleman's Avatar
05 Sedan
What would i need to use my xbox modded on my navi with a wireless remote and wireless controllers and hi quality audio. Also can u mod one of those super thin ps2s. Thanks ive been trying to figure this out to enjoy my navi screen
Old May 29, 2005 | 07:27 PM
  #179
RashMan1450's Avatar
where can i order this, I am interested
Old Jun 1, 2005 | 01:50 PM
  #180
apna_tl's Avatar
im confused with the NAVBOX. Does it work with an 2005 G35C, stock NAV? iv read in other places in the forum, and it says that as of now both the AVelectronics and PAC dont work. could someone please help out with this situation.
THanks
