NAVBOX TEST RUN COMPLETE
Old Jun 1, 2005 | 08:45 PM
  #181
MAZyar's Avatar
For those of you with the navbox installed, how to you add new mp3's? Do you unplugg the xbox, take home, sync, or do you have some other method?
I would think it would get old fast if I need to keep unplugging the whole box once a week...
BTW, is there a hot swapable harddrive solution?
Thanks
Old Jun 1, 2005 | 08:57 PM
  #182
MAZyar's Avatar
Heh, found this on newegg:
http://www.newegg.com/Product/Produc...82E16817122003
So, does it mean I can take this back and forth between my pc and xbox? Would my pc see this as a second HD and be able to see the contents? In other words, can winxp see contents that have been store in a xbox HD of I were to plugg it into my pc?
Old Jun 1, 2005 | 09:03 PM
  #183
CKwik's Avatar
Originally Posted by apna_tl
im confused with the NAVBOX. Does it work with an 2005 G35C, stock NAV? iv read in other places in the forum, and it says that as of now both the AVelectronics and PAC dont work. could someone please help out with this situation.
THanks
From what I've read, the 05 G's use a rolling sync signal which the NAVBOX does not accomodate. This could be the case for other devices as well which would also make them incompatible.
Old Jun 1, 2005 | 09:13 PM
  #184
CKwik's Avatar
I don't thnk Hotswapping a drive or even removable drives will work unless you have another modded XBOX with similar mods to accomodate the removable drive. PC's communicate with modded XBox's through FTP software. XBox harddrives are formatted differently than a PC harddrive. I do not think it will read it if you simply plug it in. But if you have another modded Xbox configured to accept a removable drive, then you can just run it off the modded box and FTP the data from your PC.
An option you might try is to use a wireless game adapter through a wireless network, but from what I hear, it's slow. I had too much trouble just trying to get my PC to see my XBox unless I ran a separate network card and a crossover cable using static IP settings so I haven't seen how slow/fast it is. You wil still need to turn the car on, but you can leave the XBox in place. If you install a power jack and a network port, you can probably make it fairly easy to plug the game adapter in only when you need it.
Old Jun 1, 2005 | 09:20 PM
  #185
MAZyar's Avatar
Rats, not the answer I was looking for... I guess I have to figure out another way... I wonder if htere is a way to fool the pc to communicate with an external HD via FTP while the drive is physically connected.. Time to do more research
Old Jun 1, 2005 | 11:40 PM
  #186
CKwik's Avatar
You might want to ask these questions to people in the XBox-Scene.com forums. You're probably more likely to find a solution there than in here.
G35VSHNG37
Oct 25, 2015 08:43 PM
GBoy
The Q - Spot
Sep 5, 2015 03:15 AM
Jiggerjuice
Aug 17, 2015 08:41 AM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
