Wrathernaut's Double-Din Installation FAQ, Shopping and Resource List
Rating: Thread Rating: 31 votes, 5.00 average.
Old Mar 15, 2013 | 02:36 PM
  #1186
Stubie1918's Avatar
Successful and easy install thanks to Wrathernaut!
Old Mar 15, 2013 | 04:08 PM
  #1187
Wrathernaut's Avatar
Gentle Manne of Leisure
Looks clean, nice work!
Old Mar 17, 2013 | 02:20 PM
  #1188
gremlin's Avatar
Hi all, I'm getting my shopping list together and have two questions about steering wheel adapters:
With the OEM stereo, when the track up/down is pressed and held on the steering wheel it seeks to the next available radio station instead of switching to the next preset station.
Do the Metra Axxess or PAC SWI retain this functionality or have any press and hold functions for the steering wheel buttons?
It looks like the iDatalink Maestro is a third option for a steering wheel adapter. It can assign secondary functions to the buttons when they are pressed and held, so it can double the usefulness of the steering wheel controls.
Does anyone have any experience with the iDatalink Maestro steering wheel adapter?
Old Mar 17, 2013 | 05:25 PM
  #1189
I see nothing on programming a secondary function in the instruction manual, despite the mention on the product page. It's up to the radio manufacturer on what it does with the signals for tap or hold of the buttons. If you look at the manual's function pairing page - http://cdncontent2.idatalink.com/cor...N_20120913.pdf - you might be able to tell what it'll do. Pioneer splits the preset up/down and seek up/down (which does track up/down on cd/iPod/USB). This prevents the steering wheel controls from acting like the factory radio, which had preset up/down and seek on the same buttons. Sony, on the other hand, only has seek up/down, so it probably does presets, seek, and track all from the same button, like the stock radio. When you tap the seek up/down on Pioneer, it changes tracks, when you hold it, it acts as fast forward, when listening to the radio, tapping increments the tuner frequency by .2 mhz, while holding it seeks the next station.
The only good online retailer I see with the Maestro is Crutchfield, where it's twice as expensive as the SWI-PS or Axxess, with no benefits over either of them for most installs, so to keep the shopping list as simple as possible, I won't add it in.
Old Mar 18, 2013 | 02:29 PM
  #1190
Electrify904's Avatar
Just wanted to say thanks for putting everything together, it helped a lot!
Old Mar 21, 2013 | 01:58 AM
  #1191
AL2275's Avatar
I have an '06 Sedan withOUT dual AC. I have the Metra double din WITH dual AC button. Does anyone know if this kit will work in my car?
Old Mar 21, 2013 | 12:47 PM
  #1192
Duriisimo's Avatar
It will work. I have it on the wifes car
Old Mar 21, 2013 | 02:54 PM
  #1193
AL2275's Avatar
Thanks!!
Old Mar 24, 2013 | 12:25 AM
  #1194
Project-G's Avatar
Hey fellow audio fiends,
I have a complicated issue here. I have a 06 G35 non-navi with Bose premium factory setup currently.
I want to change out all the speakers except for the sub inside the car to Alpine Type Rs and a Kenwood dnx890 HU. I found out later I would need to change out the Bose amp since it supports only 2 ohms speakers (type r are 4 ohms). I think a 4 channel amp should be fine right?
If I get a four channel amp, can I use the existing Bose wiring with the ROMENIS2 harness? Are there any adapters you guys recommend?
Or do I need to wire it straight from the aftermarket HU to the aftermarket amp? Any recommendations?
Also is there a way to hook up the stock Bose sub to an aftermarket amp? Bass is not big need for me but having it is nice.
Thanks in advance!
Old Mar 24, 2013 | 05:03 PM
  #1195
Thanks in advance!
If you're swapping out the headunit and amp, you've no reason to get a ROEM-NIS2 adapter. Just use the 70-7550 and run your own RCAs to the trunk. No need for any special adapter either. You can hook up the bose sub to an aftermarket amp by running wires between the amp and the sub, nothing special required. I can't say the sub will do much, but it's free, so give it a chance I suppose.
Old Mar 24, 2013 | 09:18 PM
  #1196
Project-G's Avatar
Thank you. I'm going to start shopping for my wiring.
Old Mar 25, 2013 | 09:24 AM
  #1197
serges's Avatar
So if I have dual climate control currently in my 06 coupe non nav. I cant reuse my dual climate controls from my factory stock bose hu?? I havent lookedon why but it seams like these r detachable and easy to install?? Im confused can anyone clarify also if my single a/c jdm kit will still work even if I dont have a dual jdm kit??
Old Mar 25, 2013 | 11:22 AM
  #1198
Look on why. There's an entire sticky at the top of the a/v forums, and the reasons are mentioned in the first page of this post as well. It's been clarified many times. Single zone climate control will work, the only difference between the two are the presence of the button and moving plastic on top.
Old Mar 25, 2013 | 11:35 AM
  #1199
serges's Avatar
Ok thanx I got so much on my mind w my build... im haveing a hard time paying attwntion... sorry oq I know...
Old Mar 25, 2013 | 01:24 PM
  #1200
crazy8ship's Avatar
Wrathernaut, do have a pic someone in this thread to show how to get a backup camera's wires into the trunk?
You have already rated this thread Rating: Thread Rating: 31 votes, 5.00 average.
