wideband a/f in my g need help
Old Jun 7, 2010 | 12:53 AM
gtracer33428's Avatar
alright so i want to put a wide band a/f guage in my car do i need to get a guage that has a o2 sensor or can i use the stock one because the aem is 200 is there a cheaper way that is just as good?
Old Jun 7, 2010 | 12:59 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Stock O2 sensors are narrow band.
Old Jun 7, 2010 | 09:34 AM
Shakuya88's Avatar
Actually he has a 07 so his upsteam are air fuel sensors (wideband) BUT any wideband gauge you buy will come with a sensor. And if you actually want to know your A/F ratio, get a wideband. If you want a little scrolling light that tells you nothing get a $70 narrowband gauge.
Old Jun 16, 2010 | 08:47 PM
Snakes' G's Avatar
I am looking into a/f gauges. I have a 2003 but since i have berk hfc would I just be able to put the wideband sensor in the wideband bung and leave the stock ones where they are? does it matter which cat I put the sensor on?
Old Jun 16, 2010 | 08:51 PM
GreenGoblin's Avatar
The goblin resurrection
Typically the driverside will read a tad leaner, and yes you need a wideband gauge.
Old Jun 16, 2010 | 08:52 PM
bigc's Avatar
Wings Nation
"would I just be able to put the wideband sensor in the wideband bung and leave the stock ones where they are?" --> Yes.
"does it matter which cat I put the sensor on?" --> Put it on the driver's side (slightly leaner) if you are only going to monitor one side.
Old Jun 16, 2010 | 09:01 PM
Snakes' G's Avatar
Thanks. would it be a better idea to monitor both sides? the gauges work with either 1 or 2 sensors?
Old Jun 16, 2010 | 10:50 PM
bigc's Avatar
Wings Nation
one side is fine for most folks.
9tray turbo
Sep 29, 2015 10:22 PM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
MyLilBlkG
Forced Induction
May 1, 2005 03:16 PM
GurgenPB
Forced Induction
31
Sep 14, 2004 12:00 PM
lorinserbenz
Aug 4, 2004 12:43 PM
