Tip on actuall stock sub replacment and size upgrade advice
Old Jul 1, 2010 | 01:19 PM
boostedforlife's Avatar
Hello,
to make the post short,
1st gen sedan, bose w factory navigation.
What is a good budget sub under 100 bucks for the stock location?
What is a good value sub for stock location around 200-300?
Is it possible to put a 10 inch in the stock location with out any modding and cutting?
If so what is the recommendation for a budget 10 inch and a sub of a good value around 200-300.
Thanks. I was just going to Pm Wrathernaut since I know hes the guru, but I figured better to ask publicly so maybe someone else can benefit from any of the answers anyone else shares.
Old Jul 1, 2010 | 05:30 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Step a little over the $100 mark and do this for budget:
http://www.woofersetc.com/p2643/ID8V...-Subwoofer.htm
In the 200-300 range:
http://www.woofersetc.com/p2008/21V2...-Subwoofer.htm
No, you can't put a 10" in the stock location.
Just keep in mind that you're essentially running an infinite baffle setup if you put it in the rear deck, which is going to make more noise, but won't be anywhere as clean as a sealed or properly ported enclosure.
Old Jul 1, 2010 | 05:59 PM
Thank you Wrathernaut
btw, that one says on pre order, do you have one in mind that is available now?
I just need something that is better than stock, the g35 sedans sub is a down grade from my old 02 maxima, and definitely not as good as the stock g37 sedans.
Just need something to a little better than the max or 37 quality and ill be ahppy
Old Jul 1, 2010 | 06:12 PM
http://www.woofersetc.com/p5504/8W3V...-Subwoofer.htm is another step up in price, but still a good one.
Under $100 though - http://www.woofersetc.com/p8389/REX8...-Subwoofer.htm
Old Jul 2, 2010 | 05:29 PM
jrhykushi's Avatar
So all of the links provided will be a simple stock replacement that essentially gives off more bass? Sorry. Super audio noob here
**I have factory Bose if that matters lol
Old Jul 3, 2010 | 12:33 AM
Well, they'll sound better than the stock bose sub, but without a real amplifier, they can't really give off a lot of bass.
As far as "simple" well... not nearly as simple as a 4080 or zenclosure, because getting the stock bose sub out requires removing a lot on the rear deck, and you'll also have to make a mounting solution yourself, because not all 8" subs are the same size. Compare that to just running wires to a enclosure built to fit to the trunk and running power/signal wires and it's not nearly as simple.
Old Jul 3, 2010 | 12:53 AM
jrhykushi's Avatar
damn... i was hoping there was just a cheap simple mod to improve the stock bose bass. infiniti really screwed up there..
Old Jul 3, 2010 | 01:26 AM
do you happen to know the actuall measurements of the stock sub?
Old Jul 3, 2010 | 01:34 AM
Nah, and I'm not sure if I'll remove mine in the time I've got left here in the states. If I do, I'll post up measurements.
Old Jul 3, 2010 | 01:39 AM
I suppose Infiniti holds some of the blame, but the ignorant public thinks Bose actually engineers audio equipment instead of marketing cheap, ****ty speakers, is as much to blame.
Honestly, when I removed the Bose speakers from my car and looked at them I was certain I'd pulled the speakers out of a 1984 Ford Ranger. Paper cones, shallow dish, and tweeters that looked like they came out of a $5 alarm clock radio.
Old Jul 4, 2010 | 12:50 AM
Hurt_Locker's Avatar
No doubt, I have a mint condition 1985 Bass boat and the stock speakers in that kick the **** out of the 2005 Bose speakers. All I can think of is that they were overly proud of the car and thought the driver would be more enclined to listen to the revs and the raod versus the radio, pfft were they wrong.
marsman328
Northern California
Aug 11, 2015 07:29 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
realtalk21
Jul 20, 2015 09:07 AM
nascarbuff17
Jul 16, 2015 10:23 AM
