Sound Deadening
Old Oct 14, 2010 | 09:37 PM
Itzmy04G35's Avatar
Sound Deadening
What are you guys using for your sound deadening? Dynamat? Dead Matt? eDead? Spray on?
I've used Dynamat in the past but i'm not interested in using it again because of how expensive it is compared to others, without much of a benefit.
Looking to try out something new, preferably something that gives you a little more bang for the buck.
Old Oct 15, 2010 | 03:21 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Only one I'd endorse:
www.sounddeadenershowdown.com
Just do it right - 25% coverage with CLD tiles + foam + vinyl barrier - instead of spending a ton on just layers and layers of vibration dampening.
After that, I'd say Damplifier Pro, but there's no others that I'd really spend money on, particularly not Dynamat.
Old Oct 15, 2010 | 03:32 AM
JOKER's Avatar
CLUB MODERATOR
^ wouldn't all that be to thick for some areas?
maybe in the trunk and rear seat area, but what about doors?
Old Oct 15, 2010 | 06:36 AM
Some areas, yeah, maybe, but it's more about the difficulty of getting it in there than whether there's room for the material.
Old Oct 15, 2010 | 09:36 AM
blues's Avatar
I've tried fatmat..I have not had a problem with it yet..good price better than dynamat.100sq ft of fatmat 50mil for $129 shipped,100sq ft 80 mil $160.had enough to do the doors and rear from the seat to the trunk.some places I even made it thicker...best sound deadening for the money IMO...
Old Oct 15, 2010 | 01:31 PM
Itzmy04G35's Avatar
ive been using this stuff that works pretty well (80mil for $129) but im tired of using a heat gun to get it to stick propperly and then having to pull everything appart a week or two later to reheat the corners.
ill have to look into those companies you guys sent me...thanks everyone for the input
Old Oct 15, 2010 | 01:35 PM
Itzmy04G35's Avatar
also what are the main rattle points in these cars? as in, what part of the car should i pay the most attention to when laying. i know my wife's civic was the trunk lid and in my silverado it was the rear doors and roof....i still plan on doing most of the car but i might lay an extra layer if theres one point they always rattle...
Old Oct 15, 2010 | 04:01 PM
Rear deck is #1.
Trunk #2.
Then just get doing the wheel wells and doors.
Old Jan 27, 2011 | 02:01 PM
cdub0619's Avatar
I've been looking into decreasing noise to an already quite ride with a budget under $100. I do have dampening material from a previous installation. I've heard that "stick & peel" at Home Depot is pretty much the same as Dynamat for a cost effective alternative. As for the closed cell foam like Second Skin's Luxury Liner Pro, which I think is more for sound absorption, would products found on the link below be an adequate alternative? Other ideas or suggestions are welcome.
http://www.closedcellfoams.com/index.html
Old Jan 27, 2011 | 02:09 PM
SxExCx's Avatar
I used HushMat on my '66 Nova and it works great. It is much cheaper than the other brands mentioned.
Old Jan 27, 2011 | 02:49 PM
toymachine2009's Avatar
how do you install it? Do I literally pop off door panel stuff it in and put my door panel back? Do I need to glue it down maybe? Seems like a cheap mod that would quiet down some road noise so I may just do this in the doors so I dont hear the road as much.
Old Jan 27, 2011 | 05:12 PM
Closed cell foams are great, you could get them there, or through sounddeadenershowdown.com.
The peel & stick from home depot may be as good as dynamat, but dynamat sucks *****.
The quality of the adhesive on that crap is nothing like the quality stuff that sounddeadenershowdown.com's CLD tiles use.
Damplifer's ok too, but SDS is the way to go.
Old Jan 28, 2011 | 04:23 PM
MidnightG35X's Avatar
I used RAAMmat on my G and like the results.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
