Electrical Problem. Please help!
Old 10-23-2010, 05:15 PM
WhosRich's Avatar
Ok so, long story short, I was trying to install my Usa Spec and for some reason, my car doesnt start anymore. In detail, when I put the car in "ACC" my dash doesnt light, nothing. When I put the car in "ON" position, the seatbelt, slip and vdc light come on and theres a clicking sound.
Then the airbag light starts to flash. I dont know what it is. I've been searching the forums and all I found is to change the fuses. I check the Mirror fuse, electrical fuse, nothing. I'm at my wits end guys. If you have any idea whats going, please let me know.
Old 10-23-2010, 07:32 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Received 1,036 Likes on 609 Posts
When you disconnected the battery during install (you did disconnect the battery before wiring stuff, right?) you may have not connected the terminals back on securely.
If you didn't disconnect the battery, first choke yourself.
Second, check all the fuse boxes in the battery compartment as well as those in the driver's kick panel. If you didn't disconnect the battery, and you're as lucky as you are stupid, you only burned a fuse.
If you did disconnect the battery, and it's reconnected securely, and your fuses all check out with a multimeter, you may have just wired the USA SPEC adapter wrong. Disconnect the battery, remove the adapter, reconnect the battery, see if the car functions normally, and re-check your instructions before re-installing it.
Old 10-23-2010, 08:02 PM
GeeWillikers's Avatar
Walking The Fine Line...
Nicely put! Un-do what you did and see if you get the proper result. Then you'll know. Anything else could compound the problems.
Old 10-23-2010, 08:04 PM
WhosRich's Avatar
Sorry, this thread wasnt too detailed. I posted all the details here,
https://g35driver.com/forums/audio-v...15-nis-15.html
I did un-do everything and I still had the same issue.
Freeman186
09-06-2023 10:07 AM
Danielek
05-01-2022 01:28 PM
RemmyZero
V36 DIY
04-23-2018 11:13 AM
AL8782
10-03-2015 10:26 AM
vamarris
09-26-2015 12:56 PM
Quick Reply: Electrical Problem. Please help!
