I wanna upgrade avh-p4100 to 4300
Old Mar 15, 2011 | 02:10 AM
psycobusa's Avatar
So I have a pioneer avh-p4100dvd reciever and I was wanting to upgrade to the 4300. I was wanting to know if the wiring harnesses are the same between the two models. I hated doing all that cutting and splicing the first time and I would dred needing to do it all again. If the harnesses are the same it'd be a lot easier to switch out recievers and I'll go ahead and do it. If not, I might just live with the one I have.
Old Mar 15, 2011 | 04:09 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
It looks the same to me. I'd say it's worth the gamble.
4100:
4300:
Old Mar 15, 2011 | 11:05 AM
psycobusa's Avatar
Thanks, looks like the bottom one has more pins in the top middle row......kinda hard to tell.
Old Mar 15, 2011 | 08:26 PM
8 Pins across on both, I'm pretty sure it's an identical plug, and every wire I can make out clearly is in the same position.
Old Mar 15, 2011 | 10:49 PM
psycobusa's Avatar
ah, I see now, the angle of the picture is blocking the pins....thanks
Old Mar 16, 2011 | 06:04 PM
Unleaded91's Avatar
I am kinda wanna upgrade too just for the pandora function. But I have a p4200
Old Mar 16, 2011 | 07:45 PM
Pandora can stream over bluetooth to the P4200, you just won't get anything but the audio, and maybe skip track.
Old Mar 16, 2011 | 08:13 PM
Unleaded91's Avatar
But I would néed the blutooth adaptor right? Can I use a diff. Blutooth adaptor besides the expensive pioneer one?
Old Mar 16, 2011 | 10:15 PM
psycobusa's Avatar
Well, I talked to a pioneer tech ealier today to find out if the harnesses were the same. He said that it might work or that some functions might work and others not depending on if some of the pins were switched around between the two recievers. He said there was no way to know other than trying it out.
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
NyCrAzY
Oct 1, 2015 09:19 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
