USA spec PA15-INFI
Old Mar 15, 2015 | 07:10 PM
  #121
IbanezRG7's Avatar
USA Spec PA15-INFI
So I ordered the USA Spec PA15-INFI today, since I know my 06 coupe has XM working. I'm honestly terrible at this stuff and would normally pay a dude to hook something like this up. But from reading these posts, I'm hopeful that a noob like me can figure it out. I just had a couple of questions before I attempt the install.
When I pulled open the trunk liner and lower left compartment, I don't see any exposed cables for me to attach the PA15-INFI module. I do see an XM radio module already connected. Will I need to disconnect the XM module to use the PA15-INFI, or does it somehow plug in to the XM module?
Once I connect the PA-15-INFI module, how do I snake the wire in to the car? I didn't see any openings for me to get the wire in... so not too sure what to do here.
Also, how do I ground the device?
Sorry if these questions seem incredibly dumb, I'm just worried I'll screw up my system even more if I do this install myself.
Thanks
Old Mar 16, 2015 | 10:08 PM
  #122
G2B35AGN's Avatar
The USA spec has male and female plugs on the business end that connects to the satellite tuner. You just unplug the white male plug I've circled in red and plug in the USA spec. Then stick the just removed plug into the USA spec female plug. You'll see when you get it.
As far as routing the cable into the cabin, there is a G35Driver DIY you need to search up. It's not terribly difficult, and much depends on how "invisible" you want your routing to be.
Old May 16, 2015 | 01:29 PM
  #123
sangha's Avatar
vortech v3 supercharger
Hi guys I have a 06 g35 coupe which does not have sat but is equipped with the Bose and oem navi and I ordered the pa15 Infiniti, I found the pre wired sat wire in the trunk and hooked it up to that. My radio only has radio cd paty and display buttons. I have hooked up the ground wire as well but when I press the radio or cd button the USA spec still does not work. Can someone help me with what settings I should have my dip on. Thanks
Old May 18, 2015 | 10:59 AM
  #124
LoSt180's Avatar
The answers are in this thread...... https://g35driver.com/forums/audio-v...ml#post6294273
Old Oct 21, 2017 | 04:14 PM
  #125
Jarhead74's Avatar
Have read all these threads and still having an issue. Before I return this unit, hoping for feedback, even if its send it back for the NIS version. Purchased the INFI unit.
So i have an 06 sedan. Standard radio. Non Bose. Does not have Sat or PTY buttons. I have hooked up the INFI unit and it has power as my phone has connected to it. The problem is how/can you get it to the sat mode to hear via Bluetooth. When you hit the radio button, all you see is FM1,2 and AM1,2. I have an android phone.
Old Oct 21, 2017 | 05:46 PM
  #126
Jarhead74's Avatar
Something to add. Before I connected the harness, when I cycle the radio button I see the FM/AM but also see a SR1 and SR2. But once I connect the BT45 it goes away. I checked the ground and its solid.
One thing I noticed, in the center console there is a IPOD plug the PO wired. Wonder if something is plugged into the radio causing this.
Old Oct 22, 2017 | 10:21 AM
  #127
Jarhead74's Avatar
I found my solution. Took the radio out. Found another sat/IPOD setup plugged in. Unplugged the unit and plugged factory harness. Music came right on.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
