DIY 06 Sedan Stereo Up Grade
Old Dec 9, 2011 | 08:22 PM
AJY's Avatar
AJY
I know that if you search you will find a coupe version of how to put in subs with a stock system and how to install a sat receiver. I am just giving a different opinion on how to do both. Not saying the others are bad or wrong actually I have based my efforts on the other how to's.
I also plan on continuing later with sound deadening and fixes for the rattles.
First and foremost make sure you have good wire; I am using a monster 4 gauge kit that came with the subs. I had to clip off old crap connectors for good ones. this isn't the place to cheap out.
I started by removing the under glove box cover piece
simply tug a little and it will pop free.
then I popped off the door sill
Next is the screw for the kick panel
its pulled towards the center and attached by two clips
Then just to keep from loosing it I place the nut back loosely
Next I moved to the battery
there are five of those center pull clips and it comes right off
then the plastic piece behind it has two clips
Also unhook the tube (washer fluid?) from the bottom
Now you can access the wiring harness boot
I decided not to cut a hole into it (if you want to save time this is much faster and easier just be sure to silicon it back shut so you wont have leaks)
Instead I carefully just the electric tape off
Then after freeing up the boot from the tape slide in the power cable (use the end going to the amp)
This is by far the hardest part you will have to push on the cord pretty f.....n hard to get it in there I used he fat part of a screwdriver and a crescent wrench handle to hold this thing open so I could slide the cable in.
Eventually it will pop out inside the dash board I reached up in there and just grabbed it as soon as I could get a grip on it. Its way up in there so no pic but if you look you will see it. and pull it out
Old Dec 9, 2011 | 08:36 PM
AJY's Avatar
AJY
Now its all easy you can do as I did where you move pieces as you run wire or just jump the gun and pull everything out at once (I didn't because I was in the apt parking lot and it was getting dark)
Anyway pop up the carpet and weather stripping
tuck wire under moving to the center between the doors where your going to have to pop up the back door sill and carpet as well
then the center just pulls straight out (towards the inside of the car) with a clip on each side
I ran the wire inside of the seat belt harness but you can go under the carpet if you would prefer
On to the seat which is omg easy simply pull little clip in front of the seat and lift just the seat
next run you wire under the seat area and just push it behind the flap you will feel
Didn't take a pic because well I just felt and was like lift this there's metal push wire.
Move to the trunk and pull out all of the flooring/ carpet
also pop off the side cover with the three tabs
two big ones with rings work just like the little ones
lift up the back piece and you should see your wire poking out
Again it was getting dark so I put everything back together and re wrapped the boot in electrical tape again not a place to cheap out.
Tomorrow I'll mount the ground and take out my old sat receiver since the new one should be on the way soon. I'll post pics up of how to mount it as well
Hopefully I have time to tap my aux wires into the system.
Old Dec 10, 2011 | 02:48 PM
AJY's Avatar
AJY
Sat Radio should be here Monday or Tues thanks to GraphiteGSdn for the second one.
And Quimby for the first that I mutilated.
Old Feb 3, 2012 | 11:59 PM
twanpd4's Avatar
I just spent a day installing my system and this is the first time that i did it backwards installing the sub and amp then running the cable forward. I got to the kickpanel and i was like K? NOW WHAT. been tyring to find where to send the cable down. Sunday ill go for round two now that i know what to look for. Time saver. Felt bad tearing apart my car its only 2 wks old to me.
Old Feb 4, 2012 | 01:08 AM
AJY's Avatar
AJY
Ohhh man I'm sorry I just realized I never finished this. I'll pop the rest up this weekend. Yeah it's hard to see from the floorboard up but the easiest way is to just cut the little rubber boot. I'm just a little bit of a perfectionist when it comes to wires. Don't feel bad I love the extra bass but it's cheap craigslist infinity reverence I want to upgrade the whole system. But right now paying it off is first priority. Post up some pics let's see what you have going.
Old Feb 4, 2012 | 01:09 AM
AJY's Avatar
AJY
Also sadly found out that there are two different versions of the sat radio box so I had to send the new one back to dude. Trying to fix the original one still
Old Feb 27, 2012 | 12:02 AM
AJY's Avatar
AJY
Again realized I haven't ever finished this post fail boat
Old Feb 27, 2012 | 12:35 AM
AJY's Avatar
AJY
Ok so starting with the easier stuff the Sat Radio box
NOTE there are two kinds
My 06 needs the smaller one........ sucks cause I have had them both the larger one will work but wont mount here....
top right hand side of the trunk above the bluetooth box wires should be a little further to the right maybe tucked behind the "carpet"
Anyway
run the sat antenna through this hole and you can set on your rear deck or somewhere in the cab
also far right
then you should be able to find it behind the rear passenger seat by leaning it forward and removing the carpet and just sticking you hand in the hole.
Now back to the speakers ..... the way I did it after much searing is from the blue plug (pre amp unless I got it backwards) going into the amp.
peel back some of the tape on the harness and look for these wires
Before you go hacking away I bought one of these from Radio Shack (yes I work there no you don't have to buy their shizzz)
its nice because one side plugs into your amp and the other looks like this for splicing
And then you just get some wire tap plugs.
look like this
number off the top is what the shck guys go by and its in the parts drawers
Old Feb 27, 2012 | 12:51 AM
AJY's Avatar
AJY
Ok so I clipped into the pink blue wires and the yellow brown(maybe orange) and then the green by itself as my remote. I'll double check tomorrow or sometime when I don't have to get up in five hours for class.
and if I can do it right here are some of the links I used in my massive searches
https://g35driver.com/forums/g35-sed...questions.html
https://g35driver.com/forums/audio-v...tallation.html
https://g35driver.com/forums/search....rchid=13160476
Old Feb 27, 2012 | 12:52 AM
AJY's Avatar
AJY
Not sure how correct the set up I have is for left and right but I can say that the remote works perfectly. Any input on why the wires changed colors for sedan to coupe or 04 to 06 from some of the Elders would be much appreciated.
Old Feb 27, 2012 | 03:43 PM
Hotdawwgman's Avatar
Great write up
Old Feb 27, 2012 | 05:38 PM
AJY's Avatar
AJY
Thanks man I just have to go back on double check the colors I used and get a better picture then try and find the pics I took of the grounding points. Kinda failed on doing it in a timely manner.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
hdmark
Apr 29, 2019 04:31 PM
Phalanx
V36 Audio, Video & Electronics
Aug 10, 2015 11:31 AM
yassy
Aug 9, 2015 07:31 PM
