OEM navi problems
Allow me to de-confuse some of the discussion taking place here. 03-05 G uses 6.x which does require a separate upgrade disk along with the maps disc. 2006 G brought about several improvements including the nav which no longer needed separate update discs. Take a look at the navteq shop if you'd like to see the version line for yourself. 2005 and below will show 6.x version. 2006 will show 7.x version.
http://www.navigation.com/is-bin/INT...thAmerica-Site
I've upgraded my 06 numerous times as 7.x has progressed over the years. Never ran into anything like what you guys are experiencing and I don't have an answer for that issue. What I can tell you (dj712 specifically) is your issue has nothing to do with upgrade discs. In fact, I doubt it has anything to do with your disc, it sounds like a complete malfunction to me. But if you want to take the disc out of the equation, I'd suggest taking another NAVI G for a test drive back to a location where your G is waiting to test the disc from the test drive car. Or, you're in california so I would think there would be a G meet somewhere nearby. Whatever works to try swapping with an original disc. You can swap discs all you want on an '06 and the system won't care.
You r wasting your time. I just told u I had the same issue as u. Must update software to match you DVD u r running. I had 6.4 running a 6.7 DVD. Bought the updated software n everything is fine. Pm if needed.
