'03 G35: Where does the tweeter meet the woofer wiring?
Old Oct 14, 2012 | 09:53 PM
jsm11482's Avatar
I am replacing my speakers/sub/amp in my '03 G35 sedan w/Bose. I already have a CarPC installed so after this install is complete, my sound system will be completely custom!
I am installing a component set in the front (http://www.crutchfield.com/p_777P65C...5C.html?tp=106). Each side comes with a 6.5" woofer, a 3/4" tweeter and a crossover to split the audio to the woofer/tweeter. Looking inside the door panel, I notice that the wiring for the woofer and tweeter are separate. But after looking at the wiring diagram (https://g35driver.com/forums/attachm...d-cars-001.jpg), I see that they are joined at some point.
My question is, where is the point where the tweeter taps into the speaker wire from the amp? This is where I want to install the crossover! Does anyone know? It looks to me like the tweeter and woofer wiring remains separate as it goes through the door grommet, so I assume they are joined somewhere in the chassis of the car, not the door.
Thanks!
Old Oct 21, 2012 | 07:10 PM
jsm11482's Avatar
Nobody knows?
Old Oct 21, 2012 | 09:29 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Thanks!
Thought I'd answered this or an identical question around the same time.
There's a y-split in the cable inside the door, so if your crossover isn't well-sealed, it should not be installed inside the door where the split is. Running two pairs of wires through the molex (grommet) is entirely possible, but it is a bit of a pain.
Old Oct 21, 2012 | 09:41 PM
jsm11482's Avatar
Originally Posted by Wrathernaut
There's a y-split in the cable inside the door...
Ah, inside the door - I was hoping that wouldn't be the case. I don't want the crossover in the door, it is pretty big. I will figure something out! Thanks.
Old Oct 21, 2012 | 09:47 PM
If they're weather-sealed, they can be put on the inside door skin, there's a foam filler piece (at least in the sedans) that can house a huge crossover. If you're putting them in the interior of the car, there's space in the passenger kick panel and I put my driver's side on the top side of the trim that hangs beneath the steering wheel.
Old Oct 21, 2012 | 09:50 PM
jsm11482's Avatar
Hmm...okay, I'll check that. You mean on the backside of the black metal "inner piece" where the window motor mounts?
If you're putting them in the interior of the car, there's space in the passenger kick panel...
Not any more, that's where my HD radio receiver is!
Old Oct 22, 2012 | 01:13 PM
No, on the interior door panel:
My HD Radio receiver is under the radio, plenty of room in that area.
Old Oct 22, 2012 | 01:50 PM
jsm11482's Avatar
Aha, thanks!
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
edwinisdumb15
SOCAL Meetings & Events
Mar 4, 2016 10:45 AM
