My g35 horn won’t work
Old Apr 13, 2022 | 03:57 PM
danyou123's Avatar
g35 sedan vq35hr engine stock
Hi, my 2007 g35 sedans horn won’t work and I’ve traced it down to either the clock spring or wiring from clock spring to the horn relay. I have no other electrical issues and all of my other steering wheel buttons work so I don’t think that it is the clockspring. Does anyone know what the wire color is from the clockspring to the horn relay and how do I find the break? I would really appreciate any help.
Old Apr 13, 2022 | 04:22 PM
05_SkylineSedan's Avatar
20 Year Member
Interestingly, it seems you have two horn relays and two fuses #31 & #38. Check those first! Your horn FSM is here:
https://www.nicoclub.com/service-man...2007%2Fhrn.pdf
Below the window, "click here to download a copy".
It looks like that wire from the coil to relay 1 starts as green, then passes through a GIANT wire-to-wire connector (pin-41) and is light green beyond that.
Meanwhile, here's a pic of the diagram.
Old Apr 13, 2022 | 04:25 PM
danyou123's Avatar
oh I see. Would you know the location of the second relay? I know one is in the battery bay in the relay box but where would the other one be?
Old Apr 13, 2022 | 06:21 PM
20 Year Member
The other book you might want is the "Power & Ground" FSM:
https://www.nicoclub.com/service-man...F2007%2Fpg.pdf
same thing to download a copy.
In there we find that those relays plug into connectors E11 and E18 which are here:
hope that helps
Old Apr 13, 2022 | 08:56 PM
G2B35AGN's Avatar
OP, you should just go up one level from these individual section URLs and download the entire FSM. It'll do ya no harm. Once you have them all in one folder, start with the FWD file. It's the bookmarked table of contents, and will take you to whatever section you want to check out.
Old Apr 13, 2022 | 10:06 PM
20 Year Member
I agree. Collect them all! Very handy.
Mistertones
Mar 25, 2024 09:34 AM
Magnum8
Aug 20, 2016 01:03 PM
louuu
Apr 4, 2014 09:27 AM
JDMswagSerf
Dec 31, 2012 04:19 PM
fusQer
Oct 26, 2012 03:55 AM
