Having volume issues
Old Jul 21, 2022 | 02:30 PM
GOOSEZN's Avatar
AWD (BOSE SYSTEM)
Just installed a new Pioneer MVH-620BS head unit with the 70-7551 aftermarket wire harness in my 2006 G35 sedan (w/ the Bose system) if that matters. Everything hooks up correctly and looks fine but the volume is just extremely quiet until you reach around 35-40 on the head unit which maxes out at 62 and still isn't necessarily loud. I don't think it's a power issue because I connected the ground wires to the body itself instead of through the wire harness but I'm still experiencing the volume problem. It may be a setting on the head unit itself that I need to find or I may just need to try another wire harness and start over. need help if anyone knows anything or has ran into the same issue
Old Jul 22, 2022 | 03:08 AM
05_SkylineSedan's Avatar
20 Year Member
Did you hit the "reset" button after installing. I'd try that first. Just to the left of the Aux input jack and you need a pen or something small to press it.
Old Jul 22, 2022 | 12:58 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Moving this thread to the AV subforum.
Old Jul 22, 2022 | 05:17 PM
srv2nv's Avatar
G35 Sport
You used the wrong harness to connect to the Bose system. You need to use the PAC ROEM-NIS2 adapter to maintain volume when connecting an aftermarket HU to the BOSE amp.
https://www.crutchfield.ca/S-MN8ocSg...Interface.html
Old Jul 23, 2022 | 06:55 AM
909's Avatar
909
Your mom's boyfriend
He is correct . Bose does not use standard ohm speakers (2 ohm, 4 ohm, 8 ohm ) so when you connect an aftermarket head unit to a Bose setup it doesn't match and that's why it quiet. This is why if you re-install the original head unit you'll notice it's louder .
Old Jul 25, 2022 | 09:37 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
It's not the ohms. The bose radio and amplifier are set up for a differential-balanced signal, so a standard signal being fed into the bose amp is sort of like noise canceling headphones, but the noise it's cutting is the audio signal itself.
e1an
May 26, 2018 12:09 PM
Popes
Oct 9, 2015 04:16 PM
jmgjj
Jan 6, 2011 10:22 AM
jmink78
Oct 20, 2010 12:24 AM
thedaynos
May 27, 2010 12:11 PM
