2005 Dash Dissassembly
Old May 15, 2005 | 08:09 PM
variance's Avatar
Does anyone know where I can find a guide or DIY to dissassembling the 05 dash? a coin fell behind the ashtray and now it won't close.
Id rather not take it to the dealer so they can charge me an assload..
can someone point me to a thread with pictures detailing the disseassembly or at least a good description.
I've done a couple of searches and found nothing.
thanks!
Old May 15, 2005 | 09:53 PM
Gee Im Fast's Avatar
http://www.g-owners.com/article_read.asp?id=33. Pretty much the same for 05.
Old May 15, 2005 | 10:13 PM
g35driver05's Avatar
https://g35driver.com/forums/audio-video-electronics/51031-05-dd-kit-diy.html This should help you out!
later
Old May 16, 2005 | 12:37 AM
GRider35c's Avatar
Originally Posted by Gee Im Fast
no the 05's are 10 x easier! i did a DIY, the link above (https://g35driver.com/forums/showthread.php?t=51031) in the post is mine...
Old May 16, 2005 | 01:32 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
yes....follow Kia's DIY for the 05 diassembly. you don't have to go through all the steps of the 03-04 disassembly in my DIY....
doc
Old May 16, 2005 | 08:12 PM
He has an auto though....
Old May 16, 2005 | 09:32 PM
GRider35c's Avatar
also, for automatic cars, see docron's DIY for the removal of the shift ****
Old May 17, 2005 | 02:28 PM
aznluder's Avatar
Florida G35 Club Premier Member
removal of the shift ****? When I took mine apart, I left the shift **** on and just pushed the trim to the side. I didn't know how to take the shift **** off and I got lazy, so I didn't. I don't know why, but the hardest part was getting the side of the console back on. I think that took me 20 minutes alone. Also, the peice above the clock isn't firmly in place anymore for some reason - it comes off pretty easy.
Old May 17, 2005 | 03:44 PM
GRider35c's Avatar
removal of shift **** for an automatic bro...
also, remove your clock trim, put both together as one unit before reinstalling, put the bottom clips in the hole first, then bend the top down put them in the right holes, then the bottom will go in easily
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
