stock bose door speakers 2 ohm?
Old Oct 19, 2005 | 11:40 AM
waijai's Avatar
i.love.gold
Just quick ?...the stock Bose door speakers are 2 ohm right?
Old Oct 19, 2005 | 12:58 PM
amthar's Avatar
the tweeter and door speakers are wired in parallel (there is only one + and one - for them in the trunk).
So when you ask about the door speakers, you are really talking about the pair.
Just FYI.
as far as ohms, I think I rear they are 4... who knows... lol
Old Oct 19, 2005 | 01:24 PM
AVJunkie's Avatar
Actually I'm pretty sure that it's been said here previously that they are 2 ohm. At least the ones with the Bose premium system are.
Old Oct 19, 2005 | 01:31 PM
waijai's Avatar
i.love.gold
k thanks for the confirmation AVJunkie
Old Oct 19, 2005 | 03:04 PM
Espresso's Avatar
I second this. If you're considering replacing the stock speakers with 2 ohms speakers and running them off the Bose amp, you should definately reconsider. There's nothing wrong with 2 ohm speakers, you just need to upgrade the amp as well.
Old Oct 19, 2005 | 03:24 PM
waijai's Avatar
i.love.gold
Oh I was just wanting to know because I just put in a set of Focal Polykevlars that are 4 ohm. They're not as loud as stock, and I just wanted to confirm because they're getting less juice from the stock Bose amp. My Eclipse amp should be installed by this weekend.
Old Oct 19, 2005 | 05:49 PM
AVJunkie's Avatar
Yep, that would be the reason.
Old Oct 19, 2005 | 07:14 PM
el_duderino's Avatar
I believe I measured a Bose sedan's speakers with an impedance meter and they were 4 ohm... but speaker output volume is not just a function of impedance.
Better speakers often have thicker, heavier cones with more mass, and stiffer suspensions, so output per watt is usually lower than cheap speakers. They could very well both be 4 ohm, and the Focals should be less efficient than the Bose.
EnCr1pt3d
Jul 8, 2019 02:48 PM
Bean_VQ35DE
Aug 22, 2015 09:56 PM
Tyler's03G
Aug 13, 2015 10:04 AM
Frostbite91
Aug 2, 2015 04:59 PM
