What to tap for V1 power in 05 coupe?
Old Oct 26, 2005 | 04:55 PM
RDaneel's Avatar
Question What to tap for V1 power in 05 coupe?
Hey -
I tried to find this with searches - I promise! I'm hardwiring my V1 into my coupe, and need to know what wires to tap. It looks like the fuse box changed in the 05s (as per FLFIRE's post on 8/15/05), and the only other method I have heard is to tap the ignition wires. Is there a way to tell which wiring at the fuse box is switched 12V? I'd tap into the cig lighter, but I'm not removing the center console just to figure out which wires it connects to!
Thanks,
RDaneel
Old Oct 26, 2005 | 08:42 PM
FLFIRE's Avatar
Buy a Littelfuse Mini Add-A-Circuit part number FHM200BP from Pep-Boys. Plugs directly into any circuit in your fuse box. Just pick a spare that turns on with the ignition. I believe I used the blank next to the "Power Circuit" - the fourth one closest to the front door from the fuse puller on the top.
-FLFire
Charter Member
Florida G35 Club
2005 G35C 5AT DG/Graphite/Sport/50% Huper/Clear Corners/3M Clear Bra
Drivers Side Battery Cover/Samco Intake Tube/Samco Coolant Hoses
Crawford Plenum/K&N Filter/Nismo Headers
Nismo Oil-Radiator Caps/10 Wire GroundingGear/Terk XMicro
Old Oct 26, 2005 | 08:48 PM
baileyrx's Avatar
i use my lighter outlet for most switched needs
Old Oct 26, 2005 | 09:12 PM
hayaku's Avatar
I did the same thing as FLFIRE. Works great, no cutting.
Old Oct 26, 2005 | 10:32 PM
Gee Im Fast's Avatar
The homelink wires behind your rearview mirror. Just grab some wire taps. Assuming you have the premium option on your car.
Old Oct 27, 2005 | 03:31 AM
RashMan1450's Avatar
+1 on that, since he did my car
Old Oct 27, 2005 | 06:27 PM
SLVRG35's Avatar
Or try this https://g35driver.com/forums/showpos...6&postcount=22
Old Oct 27, 2005 | 06:32 PM
Fini's Avatar
I actually did this not too long ago. i tapped it in the cigarette lighter fuse. its kinda tricky, but still works. i would tap into the rear view mirror, but i also had a conceal display that i mounted on top of my steering wheel column.
Old Oct 28, 2005 | 06:58 PM
RDaneel's Avatar
Thanks for the suggestions! I'll probably go the fusebox route, as I have a non-premium equiped car (and proud of it!)... Should be a nice clean install, too, which is what I'm looking for after having the coil wire hanging in my interior for a couple months!
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
JustinMKN1
Sep 18, 2015 03:40 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
pdjafari
Oct 4, 2005 11:21 AM
JimHarrison
Jul 9, 2004 03:14 PM
