To JL Cleansweep or not...
Old Jan 4, 2006 | 06:18 PM
  #46
m500's Avatar
I believe the original question has already been anwser in the first 5 post in the thread. No need for Clean Sweep to add IPOD connectivity as PAC will be easier & Cheaper. Also our HU output is flat already which is what Clean sweep is trying to accomplish.
Old Jan 4, 2006 | 06:29 PM
  #47
imRACERX's Avatar
[QUOTE=m500]I believe the original question has already been anwser in the first 5 post in the thread. No need for Clean Sweep to add IPOD connectivity as PAC will be easier & Cheaper. Also our HU output is flat already which is what Clean sweep is trying to accomplish.[/QUOTE
Oh ok what about the Audiocontrol LC6? Is that reccomended? do the same etc? thanks RX
Old Jan 4, 2006 | 06:50 PM
  #48
jeremyp111's Avatar
The LC6 is a 6 channel Line Output Converter. It won't do anything for adding an IPOD.
Old Jan 4, 2006 | 06:58 PM
  #49
imRACERX's Avatar
Well i do have an Ipod but i didnt even realize i could hooki it up to either. I was asking on both because im about te get an install of hifonics brutus for 2 punch Power HX2's, alpine 240 for the rest of the speaks and a capacitor with jlaudio amp kit. and they suggest at SOUNDBLAZERS, who i have choosen to be the best around, that I also go with the LC6. They said it would be the real way for install and that it would eliminate any ground noise. and im debating wether its worth it cause its 250 for the thing and additional for install. thoughts? RX
Old Jan 4, 2006 | 09:46 PM
  #50
bb996+r1's Avatar
The LC6 is a great unit. It has front, rear and sub output. The reason that I went with it is, I hate the idea if two *****. The cleansweep has one main **** and if you want to use a dedicate sub. amp volume control you would have two. The argument is that you could loop your mid/hi amp to your sub amp, but to get max performance from your amp's you really need to separate it.
We have installed several cleansweeps and have had a pretty good success rate with them. We have debated this topic at the store and doing so will be regularly stocking the LC6/LC8.
Read this months Car Audio and Electronics magazine, they go into detail on this very topic.
Old Jan 4, 2006 | 10:05 PM
  #51
imRACERX's Avatar
wow a productive post by you! I think he's coming around. But seriously, if i wish to use my bass **** from the Brutus i'll be using, is this ok with the LC6?
and whats up with the LC7 i see that is out now? thanks RX
Old Jan 5, 2006 | 09:47 AM
  #52
bb996+r1's Avatar
Funny I would advise against using the bass **** from your Brutus with a LC6/LC8.
The problem with bass ***** that are sold with amps, the act like a bass booster vs a signal attenuator. The sub amp bass ***** don't turn the gains up and down, which is what you want to avoid distortion/muddy bass. I would suggest using the optional bass **** that is sold with the LC6/LC8 because it will attenuate the sub signal vs boosting it.
Just turn your Brutus' gains to 3/4 level, adjust the level on the LC6/LC8 and you will be in heaven.
The LC7 is a new one for me. I have never heard of that one . Where did you hear about that model from?
Old Jan 5, 2006 | 07:43 PM
  #53
imRACERX's Avatar
na your right it must be the LC8 not 7 anyway. can you send a pic o0f the know? i cant seem to find it. will it fit in the ash tray along with the hifonics one? i would like to install both RX
Old Jan 5, 2006 | 10:21 PM
  #54
bb996+r1's Avatar
The **** looks like this. Mine will be going in my ash tray
celwin
Aug 1, 2007 09:34 AM
shadyg
Jul 15, 2005 04:58 PM
shadyg
Jul 1, 2005 02:19 AM
shadyg
Jun 28, 2005 04:06 PM
NiteOwl
May 6, 2005 06:48 PM
