Where are you guys grounding you trunk amps?
Old Jan 14, 2006 | 12:50 PM
speedgeek's Avatar
IS there a bolt someplace already, or are you drilling a fresh hole, with a nice metal contact. My current grnd point sucks.
Thanks!
2005 g35 coupe
Old Jan 15, 2006 | 01:51 AM
cRai6ory's Avatar
i drilled a new hole. when/if u do drill though, make sure u sand down the area around the new hole.
Old Jan 15, 2006 | 03:35 AM
speedgeek's Avatar
Thanks, I'll probably do the same.
Old Jan 15, 2006 | 02:29 PM
dartmouth01's Avatar
This is a noob question I know, but how do you figure out where to drill (so you dont cut into anything important?) Do you drill through the floor, so you use a nut and bolt from the outside? Thanks.
Old Jan 15, 2006 | 04:46 PM
G352NV's Avatar
Never enough
I used the spare tire hole.
Old Jan 15, 2006 | 05:40 PM
SI_G35Coupe's Avatar
did that provide a good ground by itself? (what size bolt is that?) or did you have to scrape off the paint and drill into the metal of the spare tire bracket itself?
Old Jan 15, 2006 | 06:52 PM
amthar's Avatar
I used the bolt that the stock amp bracket uses. I sanded all around it, works like a champ.
Old Jan 15, 2006 | 07:35 PM
silvernole12's Avatar
yeah do you happen to know the bolt size off hand?
Old Jan 15, 2006 | 07:52 PM
twinchell's Avatar
or whatever
I used one of the bolts that holds down the Bose amp.
Old Jan 15, 2006 | 08:32 PM
speedgeek's Avatar
Great info guys thanks, I'm planning on mounting the amps to the back of the rear seat, so I'll tap one of those holes around there by the frame, w/ a little sanding to get metal then once all the contact are done I'll protect it w/ something, maybe silicone sealant. I'm currently tapping a stock screw thats holding a solinoid thingy by the rear of the frame and it's not a solid ground.
Old Jan 17, 2006 | 05:07 PM
gizsf's Avatar
There is a slight problem with mounting an amp to the back seat......the backing of the seat is pretty much like cardboard. You may want to use a wood or vinyl backing under the carpeting for extra support.
Old Jan 17, 2006 | 05:38 PM
MiloX's Avatar
I used one of the bolts that holds down one of the latch U brackets in the interior cabin.
Old Jan 17, 2006 | 11:41 PM
shooter's Avatar
It's not the critic......
i used one of the existing studs welded to the trunk floor (see the 2 black wires near the date in the 2nd pic).....took some sand paper and sanded the paint off first.
as far as mounting the amps on the rear seat.....no big deal, just slide a couple of wood slats behind the carpet to give the mounting screws something to bite into....
Attached Thumbnails Where are you guys grounding you trunk amps?-dsc01647.jpg   Where are you guys grounding you trunk amps?-dsc01645.jpg   Where are you guys grounding you trunk amps?-dsc01655.jpg
Old Jan 18, 2006 | 01:38 AM
dwoloz's Avatar
I grounded on the rear defroster relay hole (brown thing in the above pictures)
Old Jan 18, 2006 | 08:48 AM
MBentley's Avatar
Hey Shooter, you're my favorite person right now. I"m about to mount my amp this weekend. How did you secure the wood to the back of the seat? Did you just slide the wood behind the two bars? Thanks.
