Dont buy MB Quarts
Old Feb 15, 2006 | 11:49 AM
  #61
shibal_z's Avatar
Originally Posted by etang789
Me and my friend have just complete our sound system one for my G35 coupe and one for his Mazda 6s.
Equipment I have:
Stock Head Unit
MB Quart PCE216
JL 300/4
Image Dynamics ID10 V.3
4080 Box
Impression:Very harsh highs, mids are ok, lows isnt great
Equipment My friend has:
Stock Head Unit
Elemental Designs edi6500s
Elemental Designs Nine.4
Elemental Designs 11kv.2
Elemental Designs Sub box
Impression: Very smooth warm High, mids are great, Low is great with the bass boost function on at the amp
Im thinking to change the speakers to edi6500s and is there any way to fix the bass thing?
I have the QSDs with the stock HU. I'm in agreement that the tweeters are bright, but it should soften out a bit after a few months. Not saying that they won't be bright anymore, they are still bright. Fixes will be to switch out the stock HU with an aftermarket with decent EQ settings to control this or go with an external EQ box to fine tune the settings. I am very happy with my QSDs and have no complaints. I'm aware of my system's shortcomings and am researching on a HU to get. So far, the '06 Alpine lineup seems lacking. I'm leaning towards the new Pioneer lineup for features and pricing, but we'll see when they are available.
I also like Focals. The tweets are mellower and softer and sounded great with ballads and classical music. My friend has a pair of Focal polyglass comps and they sound great. He did try to switch to a CDT set, but it didn't sound as good as the Focals so he switched them back.
If you want more passive control over the tweets, you can biamp the components with the crossovers that come with the QSDs. Not sure about the PCEs. You can set different settings for the tweeter and woofer independantly and tune it that way.
Bottom line is that all components in a system MUST be fine tuned to sound properly in your car. Wether through proper installation, setup, or product, they can all be tuned to sound great. Anybody that says "Drop this in and your golden." is lying to you.
Old Feb 15, 2006 | 11:59 AM
  #62
amthar's Avatar
I would have to disagree. 99% of the time EQs simply fix a problem that is being generated elsewhere. I find it odd that you should have to "fix" the brightness of a component set by using an EQ. You should not have purchased a "bright" component set if you don't like that sound... rather than buy one and try and "fix" it with an EQ (be it an EQ in an aftermarket HU or a standalone EQ).
I feel the only adjustments that should be made once you drop in a properly selected and installed comp. set is to the crossover settings. This way you are optimizing each piece in your system, but you aren't "fixing" anything.
Old Feb 15, 2006 | 04:27 PM
  #63
opimax's Avatar
Because each model car is very different shaped and contains different interiors I would not expect speakers to sound the same in different cars. I would think an EQ is the easiest fix. Whether it is a parametric or standard w/enough bands, still need some way to make up for items such as more or different angles glass increases brightness, shape of the cavity of the vehicle for bass roll off and any other effect.
Some of these items could be be fixed by different brands . Using MB Q for cars/vans that are heavey w/fabric interiors (remember the "sin bins" from the 70's w/**** carpert everywhere and no windows?) or same vehicle w/leather compared to stiff vinyl interiors?
There is a large amounty of tailoring by Xover points and phasing (mainly tweeters) but where can you try 10 different brands in YOUR car and not pay to install all 10? I don't think El D likes to work for free...
Anyway I guess I am saying never say never and what ever works use it
Mark
Old Feb 15, 2006 | 04:44 PM
  #64
etang789's Avatar
So are you saying that our interiors should use a softer sounding speaker?
Old Feb 15, 2006 | 05:19 PM
  #65
opimax's Avatar
My statement was a general about EQs and how cars are different. In our carseven the coupe is different than the sedan.
Largest variable of all is your own ears. theere is no 100% correct answer . I have 1 friend that does know when I change speakers it sounds the same to him, cheaper =better. Myself, I notice, I am not a cheap date unfortuneatly.
The best thing I can think of doing is sittring in as many cars such as ours you can find. Maybe you are in a local club??? and audition their systems. If it sounds good DUPLICATE it all the way to the wire brands.
I would think priority to replicate would be
Speakers (including location and cabinets!)
Head Unit
Installation quality
Amps
Accessories
This is open to interpetation
Mark
Old Feb 15, 2006 | 06:32 PM
  #66
el_duderino's Avatar
My rule of thumb is that an EQ is literally the last thing to buy, in that you should focus first on the voicing of the speakers you choose, before trying to force them to sound diffferent.
Most people's use of an EQ is really abuse from a sound quality perspective. That's why I'm picking up Zapco Digital Reference, the DSP chip can be set for the car and then the user can't screw it up
P.S. my install manager has a three way Quart set in one car. He got a nice PG trunk mount EQ to try to tame those tweeters, and it still never got to where he liked it fully. He's upgrading to DLS if he keeps that car...
Old Feb 26, 2006 | 09:28 PM
  #67
etang789's Avatar
Originally Posted by twinsnails
Amthar, I should have been more clear. I am under the assumption that the audio signal is being tapped from the Bose amp with line level adaptors as most installers would have done unless clear instructions were given prior to the installation, and even then it could be wired wrong.
Etang, are you and your friend tapping signal exactly the same way? did u do the install or did someone else? Are u utilizing the balanced outs or are u using an adaptor?
The other thing that could cause such a huge difference between the two systems is if the polarity of one driver is reversed or worse yet, one side is reversed (out of phase) with the other side.
Answers to these questions will probably clear things up a bit.
To answer your question is I installed both of the system. No LOCs involved all tapped before the bose amp, actually both stock bose amps are ripped out and throw in the trash. And directly connect to the aftermarket amps, suppose u call that balanced out inputs right?
And i have decided to replace my MB quarts with the edi6500s, the reason is that it fits my buget better than DLS UP6. And it is also a safe move since i havent heard the DLS myself.
I will post the results up in a few days about the edi6500s, since they are coming in tomorrow.
Old Mar 1, 2006 | 07:16 PM
  #68
etang789's Avatar
I have just finished on the speaker install. First impression the imaging is alot better, midbass is a lot better, and much clearer than the old MB Quart PCE-216.
I am very happy with this upgrade. Even the MSRP of the MB Quart is much more expensive same price on ebay, the Elemental Design is clearly much better for my taste.
It took me 1 night to install these new set of speakers, I took my time cleaning up the messy install i had before, and fix all the rattles too with foam tape.
Old Mar 4, 2006 | 03:38 PM
  #69
etang789's Avatar
Now after the edi6500s has broken in, the midbass is a lot stronger, imaging is a lot better. the midbass on the doors are so strong that i might condisder not getting the JL250/1 seems like the 300/4 is just enough power the edi6500s and ID10 V.3 . by no means its cheast pounding bass but seems ok for now. still deciding should i go through all the hassel adding a JL 250/1 and i will lose the fold down seats as well but it looks cool that way haha...
Old Mar 4, 2006 | 04:57 PM
  #70
amthar's Avatar
lose, not loose
Old Mar 4, 2006 | 05:35 PM
  #71
etang789's Avatar
sorry for the terrible english, i was so sleepy.
seagrasser
May 3, 2022 09:43 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
dorifto7
Sep 17, 2015 04:53 AM
mamba24
Sep 15, 2015 10:37 PM
twentyeggs
Sep 11, 2015 03:58 PM
