Where's the OEM alarm brain? I need to add my shock sensor...
Old Feb 4, 2006 | 05:31 AM
Disco_Monkey's Avatar
Can someone PM me with the location of the Factory Alarm brain?
I saw the DIY for adding the DEI Shock Sensor but I want to mount my sensor inside the cabin. If I can't find the brain then I will go back to my dealership or something. I really don't feel like running the wires ALL the way from the engine bay.
Old Feb 4, 2006 | 08:54 AM
KPierson's Avatar
The OEM alarm brain is integrated in to the BCM, which is mounted in the drivers kick panel. At the BCM you can grab power, ground, and the trunk pin. If you use the trunk pin you can wire ground directly to ground. If you use a door pin you MUST wire the ground of the shock sensor to the ignition wire of the car. Also, if you have an '03 you can NOT use the door pin for the trigger.
Old Feb 4, 2006 | 12:10 PM
SFLG35's Avatar
FGC President
go to www.boostedconcepts.com and in the forums there is a shock sensor diy that kevin and i did
Old Feb 4, 2006 | 01:18 PM
el_duderino's Avatar
Ah, seperating the installers from the boys
Old Feb 4, 2006 | 01:59 PM
KPierson & SFLG35, thanks that's exactly the info I was looking for.
I didn't want to run the wires because I new it would not be necessary and I also didn't feel like poking around with a test light. So thanks for the link to BoostedConcepts.com as I have printed that DIY and it looks very detailed... =)
Old Feb 5, 2006 | 09:56 PM
vodkarocket's Avatar
Modded Member
Chris, any chance I can get your assistance with this mod? I'm afraid to mess with any wiring...
Old May 4, 2006 | 01:49 PM
Down_Shift's Avatar
forum is down.. anyone want to send me the diy.. wanted to do it tonight.
Old May 7, 2006 | 11:03 AM
BoostedConcepts's Avatar
sorry about that. thanks for the notice though i had no idea it was down.
let me get you a link to a recent thread
Old May 7, 2006 | 11:04 AM
https://g35driver.com/forums/showthr...t=shock+sensor
there you go man.
let me know if you have any questions.
Old May 7, 2006 | 01:24 PM
vrsc's Avatar
+1 on the boostedconcepts info. They have great customer service and top notch products
mjfenix
Aug 17, 2017 05:49 AM
smartin0924
Aug 13, 2015 07:29 PM
Frostbite91
Aug 12, 2015 05:16 PM
JMSABO
Aug 4, 2015 11:58 AM
