Bypassing Navigation.
Old Aug 20, 2003 | 08:09 AM
R1cky's Avatar
Does anyone knows how to bypass the function to operates Navi. when the vehicle is moving?
For example: Inputing destination address when vehicle is moving.
Thanx...
Old Aug 20, 2003 | 01:53 PM
sg1717's Avatar
Re: Bypassing Navigation.
Where are all the Electrical Engineers?
Old Aug 20, 2003 | 11:51 PM
OvaYahead's Avatar
Shiot, I would love to bypass that moving cutoff too. Sucks to have to pull over and input the address. I've had to go out of my way to pull over and do that sometimes.
nice jacket R1cky.
My wife became a gixxer traitor [img]/w3timages/icons/smile.gif[/img] and bought the black and silver r6.
BS G35C 6spd navi/aero/prem
Old Aug 21, 2003 | 04:43 AM
RaySur350GT's Avatar
You will either have to reburn the rom on the NAV computer to bypass the speed sensor
-or-
you can disconnect the speed sensor from the NAV computer.
If you disconnect the speed sensor connection to the NAV comp. then you will lose your maintance info and MPG info.
- Don't argue with idiots. They will bring you down to their level and beat you with experience.=P-
Old Aug 22, 2003 | 01:45 AM
OvaYahead's Avatar
thanks for the info.
that maintanance info is pretty helpful when it comes to changing the oil.
If there is a way to reburn the rom to bypass the speed sensor, then there is a way to make the navi play movies right?
Or does anyone make some decoder that can be burned onto a disk and automatically install itself when the disk is put into the navi? Kind of like this hack i saw for PS2. Any hard core gamers in here that know all the tricks?
Old Aug 23, 2003 | 12:05 PM
sachb's Avatar
All you have to have to do is tap into the speed sensor wire and put a switch to it. Meaning when you are driving and want to type in info u tunrn on the switch making the car believe its not moving , then after you finish typing in the info then switch the switch back to off and the car will take like 15 seconds to realize where it is and there you go. i did it and it works great, i love it. check out my pic did many other modifications as well. go to:
www.clubphoto.com
in the email/friends line type in sachb79@yahoo.com
then in the private album on left column type in g35.
ENJOY!!!
Old Aug 25, 2003 | 09:12 PM
G35_Thang's Avatar
I may be a moron but I'm not sure which picture shows the switch. Could you post what the picture name is? Also, how long did it take and do you want to come to NY to do mine?
Pete
2003.5 Ivory Pearl - Nav - Willow - 6MT - 18's
Old Aug 26, 2003 | 04:37 AM
ravish's Avatar
hmm..yah its annoyin..anyone around cali can do it for me?
i dont know [censored] aobut installin switches heh
Old Aug 28, 2003 | 04:47 AM
masterlock's Avatar
Great job man. I'm also interestered in puttting a t.v. tunner in so I can play t.v. and then hook up a playstation w/ connection. Please explane how and which co. Live in L.A. cali.
G35/ sedan / navi.
Old Oct 8, 2003 | 05:47 PM
steveniemi's Avatar
Yes - I just did it. Easy fix. Interrupt VSS (speed) wire with toggle switch at back of Navi unit, white/green, flip the switch "off" when you want to enter while driving, flip back "on" so GPS mapping works.
its really easy. Drop the glovebox ( I have a sedan, probably same for coupe) and access 3 wiring harness at back of nav (DVD). All three are easy to unplug, but you only have to unplug the one with the VSS wire. I think it was the one closest to the drivers side, but may be wrong. Actually, you don't have to unplug it, but it gives you more slack to make the connection. I hid a small black flat toggle switch (looks like a mini-power window switch) in small storage area near passenger lighter outlet. It's easy to access, and when I turn the car back, the switch can be removed and no hole will be visable.
Old Oct 8, 2003 | 08:16 PM
Hitman's Avatar
The only problem is that with the VSS interrupted, the navi system will stop tracking until it realizes that your position is wrong, via the satellites. Then it should self-correct though....
Old Oct 8, 2003 | 10:17 PM
R1cky's Avatar
Kewl thanx for the info. =D i'll try it out... But one thing, when u switch off, and the vehicle is moving. Does the car position on the Navi moves? Thanx...
Old Oct 11, 2003 | 11:23 AM
Vids's Avatar
What happend to the pics??
Old Oct 11, 2003 | 05:07 PM
steveniemi's Avatar
The nav position is inaccurate when it is off and the car is moving, but it self-corrects as soon as you close the circuit again...
Old Oct 11, 2003 | 05:56 PM
SalTNutz's Avatar
I just did this mod too. Was pretty easy. I used the trunk lock switch (coupe) that is in the glove box. Since I would never use that switch anyway, now it looks factory.
06g35
Feb 14, 2022 05:59 AM
hrdwirk1
Oct 2, 2015 06:34 PM
Danielek
Sep 20, 2015 12:08 PM
