How about window roll-up via OEM remote ?
Old Mar 28, 2004 | 02:06 PM
  #211
KPierson's Avatar
Re: How about window roll-up via OEM remote ?
Yes, you can push the lock button inside the car twice and the windows will go up. But, only when the ignition is switched off. I myself have never accidently put them up though by pushing the lock button twice when the car was off. Come to think of it, I have never hit the lock button inside the car while it was off......
UPDATE: 1 Z installed Friday without a problem
http://www.my350z.com/forum/showthre...threadid=67321
Daniel has ran into a problem and I am working with him to fix it. I think I have been able to replicate his problem and I think I have came up with a solution to it. Unfortuantly though, Daniel has decided to spend his Sunday at the beach and therefore won't be able to work on it until this evening. Now, we should team up and all give him a hard time for not showing the dedication needed for a project like this!!!!!!!!!!!!!!! haha
Kevin
04 Diamond Graphite Coupe - FULLY loaded
Windows up with OEM Remote
Old Mar 28, 2004 | 02:17 PM
  #212
KPierson's Avatar
Mike,
Was your last car a Toyota??? Thats about the only car I can think of that has a real soft chirp on locking. You could easily hook up a buzzer like that, but, putting it inside the door will probably muffle it too much. I would look into getting a siren that has a 'soft chirp' feature. They are very quiet and would mount in your engine bay, making it easy to hear it. Oh, and you can hook the siren up to the (+) door lock actuator from the BCM, although I'm not sure how much current that output can supply I would imagine it would be enough for a quick, soft chirp!
Kevin
Old Mar 28, 2004 | 04:23 PM
  #213
mikeb2004's Avatar
Thanks for that tip on the lock actuator signal from the BCM. Last car: Audi A4. System from the factory lets out a little "meep" when you locked it. Not the same sound as the horn (it has an american car sound horn). The arming honk on the G is absolutely obnoxious.
Old Mar 28, 2004 | 09:56 PM
  #214
SFLG35's Avatar
FGC President
ah yes the joys of living in the south. where the weather is nice and warm even through winter. and days on the beach occur every weekend, where you load the couch into the back of the truck and head out. the water is nice and warm and the sky is clear. you have nothing to do but sit on the couch and watch the women walk by and occasionly take a dip in the clear blue ocean. what a day. so hows that cold weather goin up there in ohio for you? wishin you were hear i bet. but back to the topic, we did come home early today cause one guy had to work at 4. so upon my arrival home i began to go to work desolidering the capacitor and solidering it back on the to voltage regulator, like kevin and i had discussed. after solidering i proceeded to reinstall it and it work without problem. now for that dedication bit i believe i was very dedicate on tryin to install and figure out why it wasnt workin for a couple hours, when it should have only taken 30 45 mins. while someone else went to a car show but i dont know who that was.
i am now working on resizing all the pictures that i took so i can post them. i should have them up by tomorrow.
Daniel
5AT Coupe / DP / Premium / Aero / Clear Bra / 5% Tint - 30% Windshield / Ground Kit / Clear Corners / Shock Sensor / L.E.D. Hood Lights / Z - Tube / OEM Remote Window Up fixed and installed<P ID="edit"><FONT class="small"><EM>Edited by SFLG35 on 03/28/04 06:58 PM.</EM></FONT></P>
Old Mar 28, 2004 | 10:08 PM
  #215
PimpinPearl's Avatar
I shoulduv been a beta tester... I woulduv been dedicated from the moment the box hit my doorstep...... But I'm not jealous or anything......
Ivory Pearl / 6MT / Aero / Premium / Xenon Lights Everywhere / Mirror Tint / Injen CAI / Injen SES Exhaust / Tanabe Racing Springs / Ground Wire Kit / Apex'i S-AFC II
Old Mar 29, 2004 | 08:58 PM
  #216
SFLG35's Avatar
FGC President
well here it goes. got a lot of pics and info to post. here is the controller
Daniel
Old Mar 29, 2004 | 08:59 PM
  #217
SFLG35's Avatar
FGC President
to remove the door panel you need to remove three screws. 2 of them are behind the silver part on the door handle.
Daniel
Old Mar 29, 2004 | 09:01 PM
  #218
SFLG35's Avatar
FGC President
all 3 screws
Daniel
Old Mar 29, 2004 | 09:03 PM
  #219
SFLG35's Avatar
FGC President
remove the plastic cover up by the handle release lever to find the first screw
Daniel
Old Mar 29, 2004 | 09:05 PM
  #220
SFLG35's Avatar
FGC President
the pry off the silver part of the door handle to uncover the next 2. to get the cover off start from the bottom until you pop one of the clips then work your way up
Daniel
Old Mar 29, 2004 | 09:09 PM
  #221
SFLG35's Avatar
FGC President
then pop off the door panel. i started in the bottom left corner and worked my way around untill i got to the top. once you have all the clips released lift the door panle up and pull out to get it the rest of the way off
Daniel
Old Mar 29, 2004 | 09:11 PM
  #222
SFLG35's Avatar
FGC President
next you will need to remove the cables for the door lock and release cable.
Daniel
Old Mar 29, 2004 | 09:14 PM
  #223
SFLG35's Avatar
FGC President
you will also need to remove the wire harness that connect to the door sill light. the wire harness that plugs into the window and lock controller will also need to be unpluged but i dont have a pic of that one
Daniel
Old Mar 29, 2004 | 09:17 PM
  #224
SFLG35's Avatar
FGC President
after that i made a preliminatry mounting of the board so it wasnt in the way, but when i was finished i had to move it to get the door panel back on.
Daniel
Old Mar 29, 2004 | 09:20 PM
  #225
SFLG35's Avatar
FGC President
next i connected all the wires. which is when our little problem started happening. here are the wire taps i used.
Daniel
