DIY guide: KPtechnologies OEM alarm beep module install + video
#64
#65
Originally Posted by filanj
all you have to do is hold down the lock and unlock buttons down until your lights flash. It should stop beeping after that
Holding down those buttons will stop the horn.
How do i replace the horn sound with the beep from the intelligent key??
The key fob does the horn, while the ikey button on the door does the beep, how do i make the fob do the beep also??
#67
#68
The yellow wire prevents the module from beeping when the ignition is on. Without it hooked up the module will beep when you lock/unlock the doors even if the ignition is on.
The OEM alarm will flash the turn signals when you lock, but not unlock. The relay will allow the turn signals to flash on both arm and disarm.
#69
#70
![](https://img.photobucket.com/albums/v358/accordfreak/beep%20module%20install/G35TurnSignals.jpg)
Pins 85 and 87 can be connected to the KPtech yellow wire. The parking light output is the orange wire on the KPtech unit.
Verify the turn signal wires are correct with a volt meter before using them - I just pulled this diagram from the first post. I am assuming they are correct, but I am not 100% sure.
Tolboothwilley™
Exterior-Vendor
07-28-2016 12:42 AM
