DIY: How To Install Nismo Titanium Shift Knob - Installed Pics
Old Mar 26, 2007 | 02:04 AM
kaspia's Avatar
DIY: How To Install Nismo Titanium Shift **** - Installed Pics
I had some trouble finding detail pictures/info when I was researching on how to remove the OEM shift **** -- so -- I made a quick how-to guide.
Hope this will clear some confusion for other G members.
and yes! It is worth every penny. A whole new feeling when shifting
Old Apr 3, 2007 | 01:35 AM
Beebo's Avatar
thanks for the DIY. but where can i buy that rubber peice? no one will tell me i have a NISMO CF but cant put it on without that rubber peice!
Old Apr 3, 2007 | 01:42 AM
speedracerg35's Avatar
wes, check your bumper, i think you may have run over a dog!!!
Old Apr 3, 2007 | 02:05 AM
kaspia's Avatar
i was told that you find it at your local hardware store; such as home depot or lowe
Old Oct 18, 2007 | 05:46 PM
DefJux921's Avatar
hey thanks for the diy! I wanted to ask if your shaft rotates - not through regular shifting, but mine rotates without alot of force. i don't know if it was like this before i installed the shift **** and thats why im worried. what happened was i didn't have any extra radiator hose to use as rubber to protect my shaft (haha that does sound funny!) so i used a rubber dishwashing glove - big mistake! not only did it chew up my shaft but the thing rotated mad before i realized it... i got real scurred cuz i couldnt even shift into reverse but i rotated it kinda back and everything works now... ended up wrapping the vice grips in rubber bands and thats how i got the oem **** off.. tore the leather a lil bit but oh well. newayz, so back to my point - does your shaft rotate if you try to rotate it? did i break something or is that just how it is? im coming from honda land where the shaft doesnt rotate at all so im kinda trippin..
Old Oct 18, 2007 | 07:03 PM
kaspia's Avatar
see what happen when you dont use rubber for protection?
well back to your question...no my stick does not rotate like how you described. did you heard any clicking or a crack sound when you were trying to take off the stock ****?
I guess you might have loosen up something but if all gears are working then I you will just have to deal with the rotating shaft and not worry too much since whats done is done right? Unless you want to take it in to the shop to have it look at but then gods know how much they will want to charge.
good luck and hope everything turns out ok for you
Old Oct 18, 2007 | 10:58 PM
DefJux921's Avatar
naw nothing made an unusual sound like anything broke.. eh like u said whats done is done and it works and it doesn't rotate unless i try to make it rotate... im probably just making a big deal outta nothin.. newayz, thanks!
Old Oct 19, 2007 | 12:15 AM
BayAreaRefuGz's Avatar
i fly low
do you have to do all that to remove a shift ****? didnt know it was that complicated. i thought it's just screw on and screw off.
Old Oct 19, 2007 | 12:34 AM
superdds's Avatar
this is the correct way to remove the oem shift ****.
Old Oct 19, 2007 | 10:41 PM
DefJux921's Avatar
after some searching im pretty sure i found a post on here that shows exactly what i caused by not having a good grip on my shift control lever (wasnt holdin my shaft tite enuff!)
this also explains why i could rotate my **** and if i really wanted to i could pull it straight up! when that happened during the install i freaked out... oh well... since it doesnt move while shifting its all good... and if it starts to, its an excuse to buy a short shift kit!!
newayz, here's the post that shows what *I* think happens when you turn your shift **** without gripping below the boot:
https://g35driver.com/forums/showthr...fter+rotates#5
Old Oct 19, 2007 | 10:58 PM
O HELLA OEM's Avatar
niiiiiice
Old Nov 6, 2007 | 03:33 AM
cshih2's Avatar
where can i get this **** for cheaper price?
Old Nov 12, 2007 | 05:24 PM
SpeedNStylez_JL's Avatar
I want to change my shift **** so bad but dont wanna risk f*ing up the shifter...
Old Nov 19, 2007 | 01:14 AM
Jamaica2G's Avatar
Spiderman is frickin monster... do you turn hard a lot?
Adrian
Old Nov 25, 2007 | 01:13 PM
Jamaica2G's Avatar
I attempted this this weekend and had a bit of difficulty... couldn't get the factory one off. I held the vice Grip and my friend tried turning the OEM shifter counter-clockwise (lefty loosie / righty tighty).
Then his father got a wrench that had rubber contacting ends and he tried ... got to the point where the plastic on the shifter was starting to fracture. Please tell me I've done something wrong here...
We looked at the threading of the aftermarket shift **** (UTR) and it confirms our rotational direction. Help!
Adrian
