DIY: OEM Emblem-less Grill
Old Jan 22, 2009 | 12:34 AM
  #211
bigc's Avatar
Wings Nation
no, its never cracked. i've removed my grill countless times over the past year and have never had problems with it. i wish the clear coat i used over my killer chrome was as durable
Old Jan 22, 2009 | 01:05 AM
  #212
jlin615's Avatar
Must be the patience in good prepping.
Old Jan 24, 2009 | 07:35 PM
  #213
elayman's Avatar
started my grille about an hour ago and have the molds drying now.. I will do some touch ups and sanding/priming after.. Hope it goes well *crosses fingers*
Old Jan 24, 2009 | 09:37 PM
  #214
ShanesG's Avatar
Just finished Greengoblins, will have pics up tomorrow!
Old Jan 24, 2009 | 10:16 PM
  #215
Beebo's Avatar
now start on mine
Old Jan 24, 2009 | 10:25 PM
  #216
elayman's Avatar
i wish mine could look as good as shane's do but mines just going to have to suffice.. I'll take pics tomorrow when I finish. I have the basic mold and such done, I just forgot to pick up the bondo putty for the small imperfections.. and my humps probably aren't spaced correctly but it's fine for me
Old Jan 25, 2009 | 02:25 PM
  #217
elayman's Avatar
hey shane, do you mold the bumps on the row second to the bottom? I noticed there is a flat space below the infiniti emblem and wondering if you guys just leave that as-is or bondo new bumps on it to replicate the others. Also, could you give me a tip on how to make a temporary mold of the bumps? Should I cover them with plastic tape, then bondo a mold around them and remove it and then tape the mold and bondo the inside?
Old Jan 25, 2009 | 02:29 PM
  #218
bigc's Avatar
Wings Nation
yes, we put a bump in that spot as well. you'll need to make 4 new bumps total.
Old Jan 25, 2009 | 02:31 PM
  #219
ShanesG's Avatar
I have the bumps for all 3 rows. I made molds for all 3 spots.
A temp mold...what I just did for my first grill was just slap on a bunch of bondo the shape the bumps with a dremel and sand a bunch after that.
Old Jan 25, 2009 | 02:51 PM
  #220
elayman's Avatar
^ would that be the best/most effective method? should i not try to actually replicate the bumps making a mold w/ bondo?
Old Jan 25, 2009 | 08:25 PM
  #221
ShanesG's Avatar
^Probably, it might accually take longer that way...
GreenGoblins...
Old Jan 25, 2009 | 08:37 PM
  #222
elayman's Avatar
wow looks perfect.. i just shaped some bumps.. so it doesn't look that great but it's good enough :P now I'm letting the putty dry and then primer and paint
Old Jan 25, 2009 | 08:54 PM
  #223
bigc's Avatar
Wings Nation
take your time man. there's no reason to rush it and you'll never be happy if you see imperfections.
Old Jan 25, 2009 | 08:55 PM
  #224
elayman's Avatar
o i just noticed.. how did you get rid of the backing where the emblem goes into? did you drremel it out?
Old Jan 25, 2009 | 08:58 PM
  #225
ShanesG's Avatar
I cut everything out, i have molds so i dont just fill in the gaps!
