Diy: Sticky For Window Motor Repairs/door Panel Removal
Rating: Thread Rating: 7 votes, 5.00 average.
  #121
Old 06-19-2009, 05:47 PM
holysheetman's Avatar
I spent several hours taking the panel off my passenger door of my 2003 g35 coupe.... finally got the power window motor out, cleaned it, put it back in, no workie. I then replaced the entire unit with a new unit I bought online for around 160$, no workie.... I then checked both fuse panels (engine compartment near battery and drivers side under steering wheel) still no workie! I am out of energy for today... wow am I pissed off....
any ideas?
  #122
Old 06-19-2009, 06:44 PM
Mike_Deezy's Avatar
Problems only with the passenger's side? Is the driver's side working?
  #123
Old 06-19-2009, 07:05 PM
Drivers' side got replaced a year ago.
This passenger's side went out without warning the other day. It just stopped working all of a sudden.
The driver's side was cutting out... and then finally stopped...
  #124
Old 06-19-2009, 10:13 PM
g35man04's Avatar
CLUB MODERATOR
it could be your main sending unit over to the passenger side....thats what mine was after I replaced my window motor...
  #125
Old 06-20-2009, 08:24 AM
how do i check for that?
  #126
Old 06-20-2009, 11:20 PM
topprospect16's Avatar
I swapped the motor out last week and when ever I bring my window up automatically, it will drop a little once it is all the way up after a second. WTF did I do?
  #127
Old 06-21-2009, 06:27 AM
truexh's Avatar
same thing happening to me for my passenger side only, what sup with that...?
  #128
Old 06-21-2009, 12:16 PM
g35man04's Avatar
CLUB MODERATOR
you have to hit the reset on the window motor and you should be good...if not I would suggest taking it to the dealer because the relay I Am unsure how to fix.
  #129
Old 06-22-2009, 02:20 PM
it was definitely the Switch.
Anyone know a good cheap place to buy a replacement switch for the passenger side for my 2003 coupe? Everyone has the driver's side but not the passenger's side.
  #130
Old 06-25-2009, 04:19 PM
High Octane's Avatar
just did this in the 90 degree heat... but everything works like new. Saved me a couple hundred
  #131
Old 06-26-2009, 09:18 AM
GoDaddy's Avatar
nice job!, My window got stuck yesterday i was freaking out .... thank god it came back up after a coupe of try. Looks like it needs to be cleaned.
Thanks for the DIY!
  #132
Old 07-07-2009, 06:48 PM
jimrockford's Avatar
My driver's side window got stuck in the down position today at lunch. I tried to finish out the day at work but around 2:15 it started looking like rain. I headed home early and nearly made it before the downpour started. It figures.
Anyway, I just finished cleaning my driver's side motor and it's working again. I used brake cleaner to remove the carbon and some very fine grit sandpaper and a razor blade to refurb the armature contact area. It looked like brand new when I was done and it really wasn't that much work.
I love zero dollar repairs. Thanks for the write up!
  #133
Old 07-07-2009, 07:37 PM
kingrukus's Avatar
Well as mentioned before, I did this fix and my window worked flawlessly (drivers side) for 2 months. Now its starting to act up again - is it possible that there was some excess carbon that may not have been cleaned initially preventing it from working? Or do I need a new motor at this point?
  #134
Old 07-07-2009, 10:09 PM
If the brushes aren't making a good connection with the armature, the motor won't work. The brushes are spring loaded to compensate for wear, but it's possible they're worn to the point the motor needs to be replaced.
The brake cleaner I used did a fantastic job of removing every trace of carbon. Whether that was good for the motor itself, I don't know. I guess time will tell. If mine starts acting up in a couple of months, I'll try to remember to post here again.
If it were me, I'd try cleaning it again and test it before buttoning everything back up. If it doesn't work, it'll only cost you a little time, and swapping the motor for a new one won't be much more work.
  #135
Old 07-11-2009, 07:57 PM
sick04cpe's Avatar
Great job on the write-up!!! This helped me out a ton. I just wish i would have read further into the thread and saw that alot of you guys used brake cleaner and fine grit sand paper to get the buildup off of the contacts. Can't complain though it's my fault and the window works again but i think the motor is just had it.. I does go up and down but not very fast and sometimes just won't. Are there any differences between the oem window motor and one you can get at autozone???
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: Diy: Sticky For Window Motor Repairs/door Panel Removal
